993 gearbox adjustment/linkage question
Please help!
I have a 993 C2 non VR which I'm having problems with the gearchange. Its as if when selecting 3rd I have to move the gear lever over to the left slightly, I have changed the front lever parts which showed the pin was bent, is there any adjustment or should i change the rod from the lever to the gearbox? any help appreciated.
Cheers
Old 10-06-2007, 02:02 PM
Don Plumley's Avatar
Do you have any pictures? What caused the "pin was bent"? Perhaps the rod was also slight bent with whatever caused the other damage?
Don Plumley
M235i
Old 10-07-2007, 12:23 PM
