				964: bump steer correction
			This has been discussed in several threads recently, but I thought I would still share my experience.
				I dropped my car off at Mirage International this morning for bump steer correction. The kit makes for some serious eye candy; more pics to follow after install. Evo uprights: ![]() ERP tie rods; may require 993 steering arms: ![]() AP Racing discs, 13" diameter requires radial spacers for the calipers.
	Kris 1990 C2 2005 CS http://krisu.smugmug.com/Auto/Porsche  |
			Nice move, no more caliper adapters, lighter upright(can you get a weight on the steel 964 uprights?)
			What size rotor is that? Looks like maybe a Wrightwood hat?
	Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes |  |
			Like to see the final product.  Still high on my to do list.
			RT
	WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine. Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
 I will try to get you some weights.
			By big red offset on the rotor hats, you mean 965t or 993tt?  I am guessing you/they know what you are doing but you will need the 993 rotor offset with the evo upright rather than that of the original 965 big red.
			RT
Yes, 993TT offset for the new uprights.  My current rotors are 965 offset with the stock uprights and caliper adapters.
			I'm also a big fan of the EVO uprights.  I had them added to my car to get rid of the horrible bump steer I had once the car was too low for the stock 964 parts.  We will be cleaning the rust off in the near future ...  I also went to full monoballs and, while no photo, floating rotors with aluminum hats.
	Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)  |
			Sounds like a nice setup.  Don't forget the back and m/c.
			Any particular reason you guys went w/ the ERP tie rods instead of the factory RS pieces? From what I have learned the struts need to be 993 versions. T/F? Any other pieces necessary? I know that when I changed to the RS/GT2 uprights it made a big difference. I would imagine more so on a 964.
			Bill:  My suspension was put together by the folk at Jerry Woods/Smart Racing.  I wanted the ERP monoballs all around in addition to the EVO uprights and I assume the tie rods were easier to source as they are a normal Smart Racing product (you walk from one garage bay to another and pick them up rather than trying to order it and wait for deliver from Porsche).  I know Rich said they did a bit of additional fabrication to get the geometry they wanted given my cars ride height.
			It made an incredible difference in my car. Before the changes the car would dance and dart and move all over under heavy braking. It was a diabolical beast to the extent I really worried about contact when I had someone right next to me going into the corners. After the changes (using the same alignment specs) it became a joy to drive.
			Tom SL63 AMG Daily Driver '92 964 now a GT3R/GTL toy for track fun (Tom's Turtle) Last edited by Tom W; 03-19-2008 at 10:34 AM..  |
 I had already upgraded the rear brakes and M/C to 993 spec, plus the 60 bar P/V. Quote:
 1. the vertical portion comes in several lengths which can be custom fit for any ride height 2. no rubber anywhere Quote:
 The 964 steering rods needed to be changed to 993, as the threads are male and female, respectively. A-arm bushings were replaced with ERP monoballs. One of the drop links was replaced with a length adjustable link to eliminate any pre-load. End result: less than 20 1/1000" toe change over +/- 1" vertical travel.
 I was under the impression that the EVO upright is 1 mm wider. The struts I have on my 964 would definitely not fit if the upright mounts were wider. Any chance you could measure them precisely? Also, what were the bolt sizes? What drop links were used? Link? Thanks! RT
 Appear to be M12. One side is 964 RS, other is a ordinary heim joint (red in first pic above).
 Question: at your outer toe link connection to the upright, is there a cone feature on the tapered spacer that mounts into the upright?  |
			The 993RS/Evo mounts are 18.3mm thick.
			the upper mount hole is 12mm the lower mount hole is14mm the holes are matched to the 993/993RS bolts 12x1.5x50 upper/14x1.5x55lower 964 uses 4x 12x1.25x90 bolts(the 90 maybe a typo in PET) 964t uses the 2x 12x1.25x90 upper and 2x 14x1.5x55
 Cheers. RT I am going out to put a caliper on the 964 upright.
			The 964t 3.3 upright appears to be 18.3mm also.  So indeed the 964 strut shoud work.  Though in the case of the the 3.3t and the c2, the lowest bolt hole would have to be enlarged to 14mm.
			The 964t 3.6 strut should work with the EVO upright as is. Guess the mystery is solved. 993 struts do not look to be requred for the EVO upright.
 So to sum up, it appears that 993 or 993RS/Evo uprights will bolt on to the 964 strut w/ the caveat that 964n/a will need to enlarge the lower bolt hole from 12 to 14mm. That's great news for 964 owners that want to get rid of or not use caliper adaptors w/ the bigger 993 calipers, and/or want to use 993 or 993RS/tt rotors.
 ![]() Sory, but I'm not sure I understand your question. If you look at the second photo at the beginning of the thread there is a side view of the ERP tie rod - does this help?
 ![]() I (finally!) bought some calipers today and measured the four mounting points on the 964 uprights. They were all different, varying from 17.95 to 18.15mm. I spoke to my mechanic about the 14mm lower bolt hole. He used the 12mm bolt at the edge of the 14mm hole to get a little extra negative camber. Since it is torqued down around 100 ft-lbs, he doesn't think it will move. I, however, am a little worried that the 14mm bolt was used by the factory to resolve a weak point in the mounting, especially in the context of 18" wheels. Does anyone know if this lower 12mm bolt is at risk of breaking in this application? If so, we will drill the strut and use a 14mm bolt.
