964 C2
I'm interested in hard-rubber rear-trailing-arm bushes. Can you help me? ciao |
Yes Chuck I have noticed in my RSA that all the rubber bushings soon will need replacement.. the bushing in the suspension, Engine mounts,Transmission mounts all seem to be falling apart in the same manner..
2006 Cayman S 93 RS America white(now living in Arizona) 1974 911S/CARRERA (now living in Australia) Livermore Ca. |
be sure that there is clearance between the side piece and the body seam, some of the tops aren't thick enough to prevent contact. If that happens the mounts don'r seat properly
Insert Tag Line HERE.....
Geez, Bill, you need to wash that thing..!
It's all brake dust, and will recoat everything in very short order
Are you willing to share any photo's of your car showing rear ARB / drop link / toe link orientation? it seems that when one switches from "stock ARB to RS ARB, the ARB moves from above the toe link to below. I know that drop link mounting point on the coilover affects this relationship also. Cheers Craig
2012 Cayman R Chartreuse / 3 pedals 2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow) 2024 Audi A4 Allroad Navarra Blue over Grey 2010 Audi A6 Avant Grey over Grey - Supercharged! Lottsa "steel is real" bicycles |
there are others scattered around in various threads, I'm not currently at my main computer so don't have direct access to them
that'll do. you wrote "some concern as to why the right rear was way out despite an alignment <2000mi ago old -2* camber, new -2.5*" I too saw this from one alignment to the next with no obvious reason other than driving, or more likely measurement error by the alignment guru. best Craig
Here's the current configuration
By request some additional pics
