roofbolter's Avatar
installing a 911 decklid on to a 964
Will a mid 80's 911 SC decklid interchange directly onto a 964, same bolt holes and everything.
thanks
Roofbolter
90 C4
93 Land Cruiser
Old 11-07-2008, 03:28 AM
kurquhart's Avatar
I don't believe so. When I bought an aftermarket fiberglass deck lid, it had two sets of holes for 911 and 964/993. There may be adapters available, though.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 11-07-2008, 06:13 AM
Tom W's Avatar
I don't think so either. 964 and 993 are same size but require different hinge adapters. I thought earlier 911 were a different size.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 11-07-2008, 07:58 AM
Bye, Bye.
Scooter's Avatar
The lids are the same size, but the bolt pattern and offset is definitely different. Adapters can be made quite easily, since the offset for the 964 is more narrow. It can be done with a single plate on each side, roughly 2-3" wide, 4" long and maybe a 1/4 inch thick or so, drilling holes for the narrow hinges of the 964 and holes for the early lid. I also believe the adapters can be had at Porsche if you want to spend the money. The RS lid, is pretty much a glorified Carrera lid, so it it not unheard of to have an early lid on a 964.
If you contact John Walker, he might be able to get you a picture of the adapter. He currently has a 964 with a Carrera tail in his shop.
Elvis has left the building.
Old 11-07-2008, 08:16 AM
Don Plumley's Avatar
AFIK, there are both aerodynamic and engine cooling reasons for the moveable spoiler of the 964/993. Now if you have an old lid with a tail on it, that makes sense, except for the work of the bolt hole/hinge alignment.
If you search on the main board, you'll see that many have put a 964 lid on an older chassis - it would be the reverse alignment issue.
Don Plumley
M235i
Old 11-07-2008, 02:30 PM
120 HP/Liter is all I ask
The RSA and 964 Turbo's both used early 911 deck lids adapted with an adaptor to fit the 964 hinge. The adaptor used by Porsche is shown below, it is the cadmium plated part.
Old 11-12-2008, 07:52 AM
911 Decklid on 964
Does anybody have an address where I can buy the adapters to put a 911 deck-lid with a whale tail on my 1991 964? How much are these adapters?
Old 11-15-2008, 05:00 PM
The OEM adapters are only available together with the hinge assembly. I bought the hinges, removed the adapter and then cleaned it with paint remover to reveal the cad plating.
Part number 965.512.019.00 left and 965.512.020.00 right.
The adaptor would be easy to make with a piece of angle metal.
Old 11-16-2008, 07:21 AM
www.pelicanparts.com
Don Plumley
M235i
Old 11-16-2008, 07:39 AM
964 Hinge brackets
Cupcar,
Thanks for the information. I will not buy the whole hinge assy for just for the brackets. Can you provide me with the measurements fr the brackets please.
Old 11-16-2008, 09:49 AM
Cupcar,
I don't have the RSA wing installed on my car anymore and it is wrapped in storage and hard for me to get to.
The only dimension that is critical is the offset of the bolt centers between the hinge plane and the lid plane. Note that these are oval holes to allow adjustment of the parts so a perfect measure is not critical.
If you can find an RSA or Turbo and take a simple caliper you should be able to get the dimension easily.
The holes should already be drilled into your hinges for that dimension, if not then they can be taken at same time as the offset dimension.
Old 11-19-2008, 07:34 AM
on my '89 C4, i drilled 4 holes and used nutserts. fits fine. you just have to have a nutsert tool.
206 637 4071
Old 11-19-2008, 08:03 AM
