Chris Wiles's Avatar
Cat Bypass
Is a Cat Bypass worth doing to a 1991 stock 964? Is the performance difference noticeable?
Christopher
Old 02-27-2009, 07:18 AM
Don Plumley's Avatar
I'm not a 964 expert (Bill is much better qualified) - but I know the whole exhaust system is somewhat convoluted. The biggest benefit of removing the cat is lower engine bay heat and a little less weight off the tail end of the car. I doubt there is much if any of a performance difference.
Don Plumley
M235i
Old 02-27-2009, 07:44 AM
Bill Verburg's Avatar
A 964 cat by itself weighs 13#
here are the flow #s for each of the stock 964 components
Section Flow Rate (CFM)
Catalytic Converter 442
Primary Muffler 396
Secondary Muffler 462
As you can see, the primary restriction is in the main muffler, followed by the cat.
Bill Verburg
Old 02-27-2009, 10:27 AM
Porsche Crest
So by what your showing me the restriction at the muffler would stop any performance increase by the cat bypass? Is that right?
Thanks in advance.
Christopher
Old 02-27-2009, 10:32 AM
