Manassas, VA
lucittm's Avatar
Need Help With Fusebox Terminals
This is for the 1991-1994 964/965 cars. There may be others (993), I don't know how long Porsche used these parts.
Without getting down into the weeds, I need at least TWO of the female spade type terminals that mate with the corresponding male spade terminals under the forward fusebox. These terminals connectors look to be the standard 6.3mm width and need to be able to accept a 4mm (12 ga) wire. The GM 6.3mm metri-pak terminals don't fit.
The terminals themselves are not quite visible in the wiring harness blocks that mate to the bottom of the fusebox. Sometimes manufacturers put some unconnected spares in there - no luck. Again, they are the terminals crimped on to the ends of the wires that go into the bottom of the forward fusebox. I would take used parts if I can pry the old wire off of the terminal and use a new wire.
Even if you only have the P/N, that would be helpful. The PET is not useful because I ordered the part that LOOKED like the right piece, and it was not.
Thanks,
Mark
Here is the fusebox turned upside down:
1991 964 Polar Silver Metallic Turbo Coupe
Old 04-12-2009, 06:10 PM
