Old 60's Porsche Tech
captainlewis's Avatar
jacking points and pads 993??
what do you guys use for jacking pads to raise a 993 or do I need them, any tricks, thanks JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 04-21-2009, 11:25 AM
Tom W's Avatar
You need nothing if jacking from the side at the factory jack points. Just ensure your jack has rubber on the contact point. If you have a less expensive jack with a metal "cup" that is the contact, drop a hockey puck in it. If you use a jack with a flat metal contact on the flat metal jack point, it's pretty easy to have the jack slip off and crunch your fender. BTDT.
You can use the engine case to jack up the rear of the car. Again, cushion it so it isn't metal to metal - use a hockey puck or a piece of wood.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 04-21-2009, 12:10 PM
livesportm's Avatar
The 993 has big jacking point areas front and rear. There is a fancy part that has a pad that fits in but isn't easy with a lowered car.
I use a hockey puck on a standard jack.
Stan D
Don Plumley's Avatar
Another hockey puck user. I have four in my garage, cost a buck or two each from the local hockey rink (Snoopy's Home Ice). I use the Escco flat top jack stands under the jacking points.
Don Plumley
M235i
Old 04-21-2009, 07:53 PM
Bill Verburg's Avatar
there are pads w/ slotted holes behind the front wheels and ahead of the rear wheels.
I have a set of steel pads that lock into them, w/ wooden shims for extra height
The 4 round silver things in the middle
I have a lift in the garage, when the steel pads are prehung from the lift points it makes it much easier to align the lifting arms.
Bill Verburg
Old 04-22-2009, 05:19 AM
