Computer Display Dead on 964
The computer display which is on the tachometer has gone dead. No lights although the instrument itself works, and lights up when the headlights are switched on.
Any ideas on how to trouble shoot this? Is there a fuse? A relay? Can it be a loose connection? Where?
Cheers,
Nomi Ahmad
1991 964 Cab Tiptronic
Old 09-03-2009, 01:13 PM
put in a new bulb the old one is obviously burned out
you will have to remove the speedo
take it apart
pry off the top PCB
not hard
order a new bulb from pelican
Old 09-03-2009, 01:58 PM
Sean Hamilton's Avatar
a couple of discussions:
http://forums.rennlist.com/rennforums/993-forum/352737-obc-rev-counter-display-repair-2.html
http://forums.rennlist.com/rennforums/993-turbo-forum/168066-obc-light-fix-modification.html?referrerid=35947
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 09-04-2009, 05:53 AM
