btsave's Avatar
Question Replacing Horns on a 964
Seems like an easy fix, but where are the horn(s) located and how do I get to them on a '91 911 c-2?
I've removed the bottom panels, as well as the front lower lamps on the passenger side, which is where they sound like they're located, and all I see there is a fan. Looked from inside the boot and only see steel walls.
Thanks in advance!
Bart
Old 04-02-2010, 12:27 PM
You need to remove the passenger side wheel liner. They're higher up than where you're looking.
tom bennett
Old 04-02-2010, 02:14 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
look up high, close to the top of the spring on the strut..
1990 Porsche 911 Carrera / IMG_0008.JPG
of course, these are broken, but you can see the horns..
Old 04-02-2010, 07:03 PM
btsave's Avatar
Wow! they really are tucked up there! When I remove the inner fender skirt, will they be reachable? Thank your!
Old 04-02-2010, 08:02 PM
rattlsnak's Avatar
yes... they are right there on top of the skirt.
Old 04-02-2010, 08:42 PM
P-Zero Burner
911Urge's Avatar
Repairing the Mixo (now Valeo) Stritone horns in a 964
Stephen
2006 997 Carrera S - Sport Chrono, Full Leather
1968 912 - Purchased from Vasek Polak in 1971 and still in the family
1989 Carrera 4 - Andial service history, Sold and missing it
Old 04-03-2010, 04:32 PM
Instead of replacing them, just fix them. It isn't that hard, the directions I wrote will guide you through it. If you have questions, let me know.
Old 05-15-2010, 06:45 PM
911jettat's Avatar
Great horn repair link above!
Here's another picture, recently replaced my oil cooler ballast resistor...
'91 C2 Cobalt Blue
Gone but not forgotten:'90 C2 Slate Grey
R Gruppe bicycles - Cannondale, Titus, Specialized, Bridgestone, Raleigh, Schwinn Paramount, and Scattante TT bike.
Old 05-19-2010, 07:47 AM
Alternative horn suggestion
Thanks for a great post, the pictures really helped a ton. I fixed my problem (ended up being the 23R) but also changed out for a pair of Italian 135 db "snail-shell" horns from Autozone ($29.99 pr.). I'll keep the squeekers in case somebody wants to put it back to stock, but I like the lower tone of the new horns.
Thx again.
Old 10-08-2010, 09:57 PM
