e p slick's Avatar
993 steerin g wheel air bag removal question
Can anyone direct me to post/thread concerning procedure for steering wheel air bag removal per 1997 993.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 04-02-2010, 02:51 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
disconnect battery,
remove two torx head screws that go into the back of the airbag at @ a 45 degree angle, disconnect the plug, and youre done..
if the steering wheel is straight, the screws are @ 3 and 9 o' clock position and come into the bag at a 45 degree angle towards the center of the bag.
brain fart, i cant remember if there is 2 screws on each side, or one, but wither way, if you look at the back it will be obvious.
Old 04-02-2010, 07:08 PM
e p slick's Avatar
Thank you mister snake.
EPS
Old 04-03-2010, 07:06 AM
e p slick, are you replacing your wheel with a momo steering wheel and hub or non airbag aftermarket unit?
Dan
Old 04-04-2010, 08:04 AM
cgfen's Avatar
EPS
after disconnecting the battery, you may want to wait a bit for any residual capacitor charge to drain prior to messing with the airbag plug.
an unintentional activation would not be fun.
i would leave the ground cable to the battery connected
2012 Cayman R Chartreuse / 3 pedals
2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow)
2024 Audi A4 Allroad Navarra Blue over Grey
2010 Audi A6 Avant Grey over Grey - Supercharged!
Lottsa "steel is real" bicycles
Old 04-05-2010, 11:26 AM
