RetiredRider
Computer codes
I have a 90 C2 that is setting the following codes in the computer: 15, 31, 32, 41, 43, 44, 45. Can someone tell me what these indicate and what action the shop manual says to repair/replace? These codes all have to do the HVAC system.
Regards, Steve
1990 Carrera C2 2005 Honda ST1300 1978 Kawasaki KZ1000 1954 Chevy 3100 - project |
I think these are all. Got them from a post on Rennlist.
11=Inside temperature sensor 12=Left mixing chamber temperature sensor 13=Right mixing chamber temperature sensor 14=Evaporator temperature sensor 15=Rear fan temperature sensor 21=Oil cooler temperature sensor 22=Defrost flap motor 23=Footwell flap motor 24=Fresh air flap motor 31=Left mixing flap motor 32=Right mixing flap motor 33=Left heater blower motor 34=Right heater blower motor 41=Condenser blower motor 42=Oil cooler blower motor 43=Rear blower motor speed 1 46=Rear blower motor speed 1 44=Rear blower motor speed 2 47=Rear blower motor speed 2 45=Inside sensor blower motor
1990 964 C4 Cab 2008 Range Rover Sport (daily driver) |
You didn't list what you are using to read the codes.
I recall that with the "scantool", the baud rate is slow enough that it displays a number of codes from the CCU. I clear the CCU codes then check again - so far no lasting codes on any of those circuits.
LouZ '90 C2 TIP '08 Cayman S |
RetiredRider
I use Durametric software for scanning. It displays the code and what it is referring, but no info on what to do from there. Such as a troubleshooting guide. Thanks for the help. I will visit the Rennlist forum for more info.
RetiredRider,
were you ever able to find out what it meant? How did you fix the issue you had? |
RetiredRider
CCU codes
I eventually discovered that the codes were for the A/C and fan blower, but did not appear to affect anything. The A/C works fine, plenty of cold air and the heater works as well. So, I just left the codes in the computer. I am not sure why the codes are being set in the first place since everything appears normal. Perhaps someone who has dealt with these specific codes can reply with what action they have taken to keep the codes from coming back.
| Tags |
| computer error codes , hvac |
