Biggdawg's Avatar
Stock 993 M030 drop links vs tarret drop links
Is it worth upgrading from stock M030 front drop links to the after market Tarret type. The car is not tracked.
Thanks Bill
Old 10-24-2010, 02:18 PM
Bill Verburg's Avatar
Thanks Bill
If it's not tracked then no, If it is tracked I'd use RS drop links.
Bill Verburg
Old 10-25-2010, 01:28 PM
My Tarret links knock. And knock and knock. They've been installed and reinstalled. Cleaned, etc. Use the RS
Old 10-25-2010, 05:54 PM
trak ratt's Avatar
Friend has them and says the same thing.
Old 10-25-2010, 05:58 PM
Just curious, what are the advantages of the Tarrets? I thought the nice thing about them is that you can dial out any preload you have in the sway bars while doing your corner/weight balance?
Dan
Old 10-30-2010, 07:48 AM
Yes. And they're pretty. Another example of race car stuff that doesn't translate well on the road.
Old 10-31-2010, 11:10 AM
Biggdawg's Avatar
Thank you all,
I've decided to use stock RS drop links
Old 11-06-2010, 01:32 PM
