Jeff Mohrlock's Avatar
Porsche Crest Clock no tick toc
Man am I thankfull for the information provided by the great people in this forum. OK, I have a 1990 C2. The clock stopped working. I took it out and did a visual, looked like the ground, (small connector), was kinda weak so I re-soldered it. Clock does still not work. Does one of you fellas know what wire(s) power that clock? I don't think I'm getting power to it. I have already checked fuses/relays/etc. Thanks very much.
I'll work 3 jobs to keep my cars
Old 12-09-2010, 05:27 PM
Jeff,
If I'm not mistaken, Pin #30 is Power, Pin# 31 is Ground, Pin #1 illuminates the clock, and the single large pin gets grounded via the adjuster switch to advance the time.
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2002 Toyota 4Runner, Dorado Gold
2001 Toyota 4Runner, Dorado Gold, 604,XXX 1-owner miles
1998 Toyota 4Runner, Oxidized, 5-speed
Old 12-10-2010, 06:27 PM
RetiredRider
RetiredRider's Avatar
1990 964 clock
If you decide to have your clock repaired, I can recommend an excellent guy in Atlanta. His prices are reasonable and his turn around is outstanding. Hamp's Speedometer Repair. Phone is 770.777.1919.
No affiliation other than he has repaired my speedometer and clock.
1990 Carrera C2
2005 Honda ST1300
1978 Kawasaki KZ1000
1954 Chevy 3100 - project
Old 12-11-2010, 02:57 PM
Thanks very much gentlemen. I will check for power/proper ground at those spots and use the Atlanta fella to repair it if I can not get it figured out.
Old 12-14-2010, 07:14 PM
