-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   993 C2S refurbish..project log (http://forums.pelicanparts.com/porsche-964-993-technical-forum/589029-993-c2s-refurbish-project-log.html)
Resident Sicko 01-31-2011 12:17 PM
REFURB JOURNAL:
1998 Porsche 993 Carerra S. 38 miles, Factory Turbo S Aero, Sport Hardback seats, full leather, Carbon Fiber, LSD, Arctic Silver/Boxter Red, Motor Sound Package, Hi Fi Audio, COA, Window Sticker and all documentation.
http://i304.photobucket.com/albums/n...ject/front.jpg
http://i304.photobucket.com/albums/n...oject/side.jpg
http://i304.photobucket.com/albums/n...oject/rear.jpg
Before:
12 years of limited but careless use. Rock chips, dirt, aftermarket undercoating, and general deglect.
http://i304.photobucket.com/albums/n...t/993008-1.jpg
http://i304.photobucket.com/albums/n...ect/993009.jpg
http://i304.photobucket.com/albums/n...ect/993037.jpg
http://i304.photobucket.com/albums/n...ct/9932003.jpg
After: Repaired crack in the underside of Factory Aero lip, Plugged front tag holes, replaced grill, Stripped and resprayed front fascia, replaced headlights, split and reconditioned OE projector fogs, added clear corner lenses. Cleaned out Oil cooler and A/C inlet, replaced all clips, foam and secondary parts with OE Porsche.
http://i304.photobucket.com/albums/n...ect/feb017.jpg
http://i304.photobucket.com/albums/n...ect/feb019.jpg
http://i304.photobucket.com/albums/n...ect/993038.jpg
http://i304.photobucket.com/albums/n...ect/993004.jpg
http://i304.photobucket.com/albums/n...ect/993006.jpg
Resident Sicko 01-31-2011 12:23 PM
Before:
http://i304.photobucket.com/albums/n...ct/9932004.jpg
http://i304.photobucket.com/albums/n...t/SANY0791.jpg
http://i304.photobucket.com/albums/n...ect/993020.jpg
After:
New Bilstien HD, H&R springs, Replaced all clips, retainer nuts, Links, and all other take off with OE Porsche. Added K&N filter for now with complete fluid change. 10 gallons of Mobile 1!
http://i304.photobucket.com/albums/n...ect/feb022.jpg
http://i304.photobucket.com/albums/n...ect/jan008.jpg
http://i304.photobucket.com/albums/n...ct/9931012.jpg
http://i304.photobucket.com/albums/n...ect/feb023.jpg
http://i304.photobucket.com/albums/n...ect/feb028.jpg
Magdaddy 01-31-2011 05:58 PM
wow, looks spectacular. One of my favorite color combo's. What did you do to the headlights, clean(and how) or replace?
thanks
Resident Sicko 02-01-2011 05:10 AM
thanks
Replaced with new lenses, bulbs and added Headlight Armor. Word to wise: it took three tries as the "blue tint" is far too blue, the "light smoke" is far too dark so I went with clear.
Before:
http://i304.photobucket.com/albums/n...t/Interior.jpg
http://i304.photobucket.com/albums/n..._A_565x377.jpg
New MoMo Porsche 993RS Steering Wheel and Spacer..
http://i304.photobucket.com/albums/n...eringWheel.jpg
http://i304.photobucket.com/albums/n...ect/993005.jpg
http://i304.photobucket.com/albums/n...ect/feb002.jpg
(Note the factory option of the push and slide "cassette" holder. Apparently, a Kass'Eht. was a tool used to record and play music. Replaced with OE console pocket.
http://i304.photobucket.com/albums/n...ect/feb005.jpg
Also added new floor matts from Lloyds.
MCIPSERIC 02-01-2011 08:24 AM
you da man!!
bri450sl 02-02-2011 05:14 AM
What kind of jack stands are you using? Did you have some sort of retrofit you did for the plate?
Resident Sicko 02-02-2011 05:34 AM
Neither. It may have not been the best way to go, but I simply positioned the jack stands so that the inside of the top hat nested in the "German Holes".
Oddly enough, I am developing a protoype to be used for a better and more stable setup.
Updated all OE bulbs, interior and exterior with LED, most were buned out in gauges...
http://i304.photobucket.com/albums/n...oject/m014.jpg
Update 11 March
Stripped Stone Guard off big hips. Replaced with new OE.
Before:
http://i304.photobucket.com/albums/n...t/March002.jpg
http://i304.photobucket.com/albums/n...ect/993011.jpg
After:
http://i304.photobucket.com/albums/n...t/March015.jpg
Cleaned out boot- Added very cool, light and strong strut tower brace. (solid)
Before:
http://i304.photobucket.com/albums/n...t/March019.jpg
After:
http://i304.photobucket.com/albums/n...t/March023.jpg
http://i304.photobucket.com/albums/n...t/March021.jpg
Removed factory stainless exhaust to store. Replaced with lighter, louder Fabspeed Supercup system. (loud bark, throaty idle)
Before:
http://i304.photobucket.com/albums/n...ect/jan009.jpg
After:
http://i304.photobucket.com/albums/n...t/March024.jpg
http://i304.photobucket.com/albums/n...t/March016.jpg
autobonrun 02-05-2011 09:17 PM
very nice work.
Really a great job. I may have to put those LEDs in my SC.
Nitro 02-06-2011 05:28 AM
Nice, now add a couple of turbos and you'll be just fine!
bri450sl 02-13-2011 07:49 AM
How do you keep the "top hat" on your brake disks so clean? Mine has a good amount of surface rust which looks terrible. I was thinking of painting them. Did you paint yours or do you have some sort of secret to stop them from showing surface rust?
johnsjmc 02-17-2011 06:48 AM
I think your horn problem is related to the airbag mounting . I read that there is an inexpensive (< $100) mounting bracket which wears and allows the bag to move causing horn to honk. Search
Resident Sicko 02-17-2011 10:35 AM
I dont think so.
The airbag was removed and will remain with the stock steering wheel in storage. I used a 3 ohm resistor to close the circut as found on Rennlist assistance.
Traveller 02-17-2011 10:35 AM
Originally Posted by Resident Sicko (Post 5818836)
Hey, no cheating! Where is the "after" pic of the underside of the engine...and transmission?
Resident Sicko 02-17-2011 01:42 PM
LOL....still in process....and very may well be for the next few years. After being spoiled with new cars for the past decade, this "old car" stuff is almost as tough as building a street rod!
Jim Dorociak 02-21-2011 08:31 AM
I have Speedline Datona, 993 RS, 3.6 Turbo and Alessio centers available for a special widebody build. Jim jdorociak@gmail.com
http://forums.pelicanparts.com/uploa...1298305612.jpg
http://forums.pelicanparts.com/uploa...1298305649.jpg
http://forums.pelicanparts.com/uploa...1298305690.jpg
http://forums.pelicanparts.com/uploa...1298305769.jpg
http://forums.pelicanparts.com/uploa...1298305799.jpg
Resident Sicko 02-21-2011 02:07 PM
Oh great. Now I have to look at these beautiful rims I want before I post up the rims I will be getting...
Unless I find a buyer for the Fikse FM5s..
Resident Sicko 03-11-2011 10:52 AM
Updated images
jetstar911 03-11-2011 11:24 AM
I love the attention to detail, nice work. Beautiful car.
Don Plumley 03-12-2011 11:42 PM
Well done!
