Now in 993 land ...
aigel's Avatar
Anyone use the WEVO shift coupler?
Looks like my coupler has seen better days. Instead of stock replacement I found this. Not cheap but don't ask what the stock piece costs. I'd have to make my own for that money ....
Pelican Parts - Product Information: WVO-PSJ-993
Any of you have experience with this piece? Only down side may be louder interior noise. I don't mind the right noise, but transmission whining like I have heard it in cars with solid mounts etc. can be very annoying. Please let me know!
George
81 SC (sold)
Old 03-06-2011, 11:27 PM
cgfen's Avatar
would the FD golden rod conversion work for you?
FD Motorsports - Short Shift Kits, Shift Rods, Rothsport Short Shift, Porsche Clutch Kits 993 2WD Conversion
NVH has not notable increased for me.
2012 Cayman R Chartreuse / 3 pedals
2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow)
2024 Audi A4 Allroad Navarra Blue over Grey
2010 Audi A6 Avant Grey over Grey - Supercharged!
Lottsa "steel is real" bicycles
Old 03-07-2011, 12:05 PM
Now in 993 land ...
aigel's Avatar
cfgen:
Thanks for your input! That's intriguing. So you run that rod? Only down side is that it isn't nicely packed in a boot like the Wevo unit, OTOH it is "one piece and follows what the factory did, what could be better? I will definitely check into the FD unit more closely. The stock piece is in N/A land in terms of the price at > $300 for a rubber disk and some hardware ...
A little more reading even brought to light some people that replace the rubber disk with a set of same thickness washers. No worries, I am not that cheap.
Now I only need to resist the urge to install a short shift kit. I don't mind the relatively large throw - it gives very clear indication where you are at and the gears go in easier.
G
81 SC (sold)
Old 03-07-2011, 10:44 PM
Hi George, I have a vested interest, so should offer that first......
However, I have a bone stock '95 993, 130K miles, that we have used as a test mule for several WEVO product development exercises for that series.
The ONLY WEVO product left that remains on the car is the 993 PSJ as it made no increase in noise (to our ears) but left a nice crispness in the shifter that did not exist previously.
This is a car with stock everything, so a very true test of the change in the NVH quota.
Regards,
Hayden
Old 03-08-2011, 01:27 PM
cgfen's Avatar
i am in the process of going back to AWD after i had done AWDectomy 2 years ago.
i needed a goldenrod or similar to do the conversion.
i like the GR and will keep it when i go back to AWD.
i'm not a big fan of the SS kit, shift action is not as "precise", but that may be just because i also switched from the AWD mounting configuration at the same time i tried the SS kit.
AWD shifter mounts to the big black TQ tube shaft, RWD shifter mounts to a "flimsy" sheetmetal box.
good luck
Craig
Old 03-08-2011, 07:33 PM
Now in 993 land ...
aigel's Avatar
Regards,
Hayden
Hayden,
I appreciate the input. What I like about the WEVO coupler is the self contained joint (I do plan on keeping the car for a long time) and the fact that I don't have to mess with the shifter end of the rod. Now that the trans is coming out, this will be a perfect time to do the replacement in 10 minutes time!
Cheers,
George
81 SC (sold)
Old 03-08-2011, 08:10 PM
Now in 993 land ...
aigel's Avatar
Just wanted to update this thread. I ended up buying the WEVO coupler and it is a top notch piece and works great. I can't comment if it helped on the shifting or not as the transmission was totally rebuilt, so I changed two things at one time. There is no noise increase or vibration of the shifter.
If you need another 993 test mule, let me know. I need to "test" those engine and transmission mounts next!
Cheers,
George
81 SC (sold)
Old 08-12-2012, 12:14 AM
Alex973's Avatar
I used both wevo and stomki racing couplers both work the same
"IGNITION LEFT OF STEERING"
Alex
Old 08-21-2012, 05:22 PM
