Electrical issue speedometer / odometer
Hello,
I have an intermittent electrical issue causing my speedometer and odometer stop functioning a bell will chime and the ABS light turns on the cruise control stops working also the rear spoiler will not go down until everything starts working again. This problem has gotten worse lately and happens almost every time I drive the car. Very rarely will it start working again while driving. But starts out working almost every time I start the car for the first time in a while.
Any advice on where to look for this problem?
Thanks for your help,
Chuck
Old 05-22-2011, 01:37 PM
PNine64's Avatar
My car had a similar issue and it ended up being an ABS relay. I've seen folks post similar symptoms but have different causes though (speed sensors etc).
Travis
1993 964 Oak Green Metallic C2 Targa
Mods: H&R Reds, Bilstein HDs, Cat Bypass, Cup Bypass, Steve Wong Chip, Strut Brace, Wevo Black
Old 05-22-2011, 01:48 PM
Thanks Travis
Where is the ABS relay located?
Old 05-22-2011, 01:52 PM
PNine64's Avatar
In the front, passenger side, in the black fuse box to the right of the shock.
There is a small discussion on it...HERE.
Travis
Old 05-22-2011, 04:50 PM
