Certified User
billjam's Avatar
Clutch discs - with or without sprung centre?
I am shopping for clutch parts and I'm wondering what determines whether I should use a disc with sprung centre or solid centre. (or should that be center? ).
The application is a daily driver '88 Carrera with a 3.6 conversion. Flywheel is lightweight 1992 RS with a 90-94 964 pressure plate mated to the original '88 G50 box.
I can see that the sprung centre might be kinder to the transmission. Is that the only advantage?
It seems like there is a mix of sprung and unsprung discs used across all models without any apparent logic.
It also seems that discs are pretty much interchangeable from 1987 to well into the nineties - correct?
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 10-15-2011, 01:00 AM
Bill Verburg's Avatar
There are only 2 sorts of street clutches available
1) spring center
2) rubber center
both absorb shock from clutch actuation, the rubber absorbs gear rattle a little better, the rubber is very heavy
the rubber center has been problematic in the past and most have been replaced over the years w/ a spring center, the rubber center was oe for most model 911s from the '70s
I'd use a spring center clutch, that was what was used on the 964RS, the part #s have probably been superceded as the same clutch was used thru late 997 GT3s
Bill Verburg
Old 10-15-2011, 05:06 AM
The dual mass flywheel (DMF) uses the unsprung disc. The DMF does the dampening instead of the disc.
Since you have the lightweight FW, i would use the spring centered disc.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-15-2011, 06:03 AM
forgot about that one
here's a dual mass setup from a '93 964, top left is the dual mass clutch disc, top right is a normal RS type spring center
the dual mass clutch is incompatible w/ the 964 RS flywheel, only the rubber center or spring plate versions are
here's a complete 964RS setup
Bill Verburg
Old 10-15-2011, 06:57 AM
