964 Engine Running Issue
My 3.6L has started running funny, and it just came out of nowhere.
Symptoms:
I run Techron thru it every now and then, the last time being early last week. Any clues? I've done the obvious hose-and-connector checks. I'm still really new to these engines.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
does this 1977 3.6L have the same DME at the 964 series? I had a problem like this; when I replaced the DME relay, it was cured. Also, could it be that your dual-distributor belt has snapped?
