964 induction system question
does a 964 engine have only a two stage throtlle body ? or does it have a valve that opens at a set rpm from a vaccumn signal?
2006 Cayman S
93 RS America white(now living in Arizona)
1974 911S/CARRERA (now living in Australia)
Livermore Ca.
Old 02-28-2011, 08:37 PM
Shamus911's Avatar
The latter - the resonance valve inside the intake piping opens at 5500 rpm
Old 02-28-2011, 10:24 PM
thanks shamus
2006 Cayman S
Livermore Ca.
Old 03-02-2011, 08:34 PM
Bill Verburg's Avatar
there were 2 different throttle bodies
early used w/ aluminum manifolds
late used w/ plastic manifolds
a different question is the intake manifold, which has dual geometry's controlled by 2 resonance flaps. The resonance flaps are are activated by the DME via a vacuum operated electronically triggered solenoid after reaching 5500rpm, then close when the rpm drops below 5400. Additionally the flaps are activated briefly each time the ignition is turned on.
Bill Verburg
Old 03-03-2011, 05:54 AM
Carmagic.us
rothaus's Avatar
I have some question: I have the plastic manifold, and the solenoid is not operating when the ignition is switched on. The green/black wire has 12V when the ignition is on. When I connect the gray/white wire to the ground it operates. Could the issue be in the DME ?
Also from what year was the plastic manifold used, my engine is supposed from a 1990 car.
Thanks for any info on that.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 02-27-2012, 04:43 AM
