96 4wd
I am considering purchase of a 1997 4WD manual trans 911. I have owned many, many 911s but never a 4WD and wonder if this model, especially at its age and 92K miles, is something to avoid. The car performs well at the moment but I don't want to buy something that is likely to present problems.
ANOTHER QUESTION: Can the front drive be disconnected and the car utilized as a 2WD? Thanks Eldon eps930@gmail.com http://eldonpslickracecars.homestead.com/Home1.html
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - Last edited by e p slick; 05-27-2013 at 08:15 AM.. |
I have 236k miles on my 92. These go forever.
steve old rocket inguneer |
A 92 964, is NOT a 97 993. Apples and oranges.
You'd get a much better response at rennlist.com in the 993 forum. As good as Pelican is for early through 80's 911, Rennlist is for 993/996/997 and maybe even 991's.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Yes, it can easily be disconnected and removed from the the car if you so desire
![]() More than a few track-ers have removed it for better handling (weight savings and 2wd goodness) and others have left it intact for the AWD benefits off track and in the elements driving (on and off track). Save the parts if you do remove it for the next owner. |
Thanks everyone for your responses.
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
