si Banker's Avatar
Adding Power Stearing To A 964
How hard and expensive would it be to retrofit power steering to a 1993 RS America. I have Parkinson's and am loosing upper body strength
I don't think it would be hard to redo it back to stock. Also, I do not care what the changes do to the value because all a RS is is a 2wd drive 964
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 12-05-2013, 05:18 PM
Neerlandofiel
JordanPryce's Avatar
It's not impossible, but it's not an easy job. Costs for the rack pump and all the related bits will run a few thousand plus installation. RSA racks are easy enough to sell, but I'd keep it with the car.
With the values of RSA's at an all time high, you should really consider selling it and buying a new Cayman or Boxster. They are amazing machines and much easier to deal with at low speed.
1990 944S2 Baltic Blue 1,960 original miles
1989 944S2 Guards Red 82,000 miles
Gone: 06 Exige, 08 Cayman S Sport, 67 911R Hotrod, 09 Cab, 93 RSA, 91 964, 13 Boxster, 15 Macan S, 05 Elise, 00 M-Coupe, 71 914-6, 75 Carrera, 11 997 GTS etc..
Old 12-05-2013, 05:59 PM
Instead of retrofitting an OEM setup (which was never available on an RSA), consider an electronic power steering pump mounted in the front tub. There's a Porsche Motorsport pump that is popular for such applications and the third generation Toyota MR-S/MR2 pump is also popular. Basically you'd need a power rack off of a C2/C4 and do some fabrication of lines and give the pump power.
For example, using a Mercedes A-class pump.
http://forums.rennlist.com/rennforums/10470846-post96.html
http://forums.rennlist.com/rennforums/10485574-post114.html
Old 12-05-2013, 06:43 PM
+1 On the Toyota pump. I have it on my C2 track car for weight and power savings and it works great.
Old 12-06-2013, 06:56 AM
^It's on my "modification wish list"
Looking at the mess of OEM PS hardware and lines in the engine compartment annoys me. I can't wait to ditch all that.
Old 12-06-2013, 07:02 AM
si Banker's Avatar
PS pump
Thanks for the great idea. I was not looking forward to dealing with all the Porsche parts. It sounds like what I really need is the rack of a C-2.
Thanks for the infof
1987 911 Coupe
Old 12-06-2013, 09:24 AM
kuehl's Avatar
I recall the ratio is different on a 993 vs. 964, you may want to test drive
a 993 and see for yourself.
Old 12-19-2013, 08:21 PM
Who here has first hand experience with the electric PS pumps?
I am pondering replacing my (leaky) setup with an electric pump, and would like more info about the level of assistance. The 964 steering is a light assist, not a buick style one finger steering job.
Old 12-19-2013, 10:57 PM
Kartoffelkopf
Spenny_b's Avatar
These guys are getting a lot of press coverage over here in the UK at the moment --->
EZ Electric Power Steering
EVO magazine's Harry Metcalfe had them fit a system to his Countach, Octane recently fitted one to editor Crouchers classic Jaguar. All the systems have variable assistance via a potentiometer hidden from view - everything looks bone stock and is of course reversible should you want to sell the car on. No affiliation, but a pal of mine also makes very similar setups for rallying and racing Ford Mk2 Escorts, with great success.
HTH
Spencer
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 12-21-2013, 03:10 PM
si Banker's Avatar
steering rack
Any body have a c-2 or c-4 rack for sale
1987 911 Coupe
Old 12-24-2013, 05:07 PM
Thanks for the link Spencer. I just wrote them a email to get more information about their system. I'll post their reply when I get it.
I'm in Spain for the winter. If I get a reply from them I like, I'll drive my RS America to them in April or May for installation. I'll post about that too.
Driving around Europe with manual steering can sometimes be a real ***** on narrow medieval streets. Yesterday I was driving on some to get to a castle. There were spots where I was lucky to have 3-4 inches of clearance on the rear view mirrors. I was actually driving half on the sidewalk to get past some cars and no there isn't enough room to turn around. Backing up is scary. A wide body would be screwed.
Old 12-25-2013, 03:17 AM
non-whiner
mreid's Avatar
If you decide to go stock, I have all of the engine mounted components (pump, bracket, pulley, belt, etc.)
"Too much is just enough."
Old 12-25-2013, 05:15 AM
Googled EZ Electric Power Steering and found this. Real Interesting.
Installation of EZ Electric Power Steering
Old 12-25-2013, 07:04 AM
I don't think that setup is gonna work on a 964. The only place you'd be able to mount anything like that might be under the dash, and you can go look down there, it isn't spacious at all.
Old 12-25-2013, 04:00 PM
si Banker: Was this you at Cars & Coffee this month?
Old 12-25-2013, 04:01 PM
I've installed power steering racks and 997 cup PS pumps on several RSA's
IMHO it's a great improvement and not terribly hard to do.
Due to the electric pump having lower pressure I think the steering feel is better then a standard 964. I like to use the 993 rack
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 12-25-2013, 06:01 PM
I believe you'd also need to open up the motor to swap out the camshaft since the RSA cam doesn't have the PS pump drive gear on the end.
Old 12-26-2013, 06:21 AM
si Banker: you have PM
Old 12-29-2013, 02:19 PM
Got this email back from them. Sent a email to the shop in the Netherlands, think that would be the shop I'd go too.
Hi Don,
Thank you for your e mail, it sounds like you get around in your Porsche, where are you based? I only ask because our main workshop/ factory is in leerdam Holland. And they have converted a number of LHD 911's
The price varies between 1300-1400€ ex vat & fitting depending if it's a car with A/C
Or I am able to do the installation here in UK (Devon) for £2,350 fitted inc Vat
Kind regards
Mike Waters
EZ power steering UK
07967 439596
Old 01-01-2014, 01:30 PM
si banker
if you do convert over to the power steering i would love to purchase the manual rack from you. or does anyone else out there have one for sale?
regards
pf
Old 01-03-2014, 09:59 AM
