Hello,
I seem to have a small oil leak in the front of the engine. Looks like it is coming down between the engine and engine carrier. Is this likely to be front main seal /Crank seal? Can this be fixed without removing the engine? ![]()
Frode L. Porsche 993 4S |
I'm assuming this is the part of the engine that is closest to the rear bumper. If yes, this could be your #8 bearing outer seal and can repaired with the engine in the car.
You would need to remove the crankshaft pulley to get to this seal. It's about a $30 dollar part, but about 3 hours in labor....I think. It took me about 45 minutes to remove the crankshaft pulley on one of my diy jobs at home. Check out our videos at P Fix It | Porsche 964 | Repair & Maintenance Videos, we may have a view of this on a preview video. PM me if you want to talk through the job and how to do it. Not that bad actually. You'll need a big torque wrench to torque the crankshaft bolt to the correct torque sequence. Thank you, dmark9 |
Tags |
993 , crank seal , front main seal , oil leak |
