Question 993 Oil leak - Front main seal??
Hello,
I seem to have a small oil leak in the front of the engine.
Looks like it is coming down between the engine and engine carrier.
Is this likely to be front main seal /Crank seal?
Can this be fixed without removing the engine?
Frode L.
Porsche 993 4S
Old 12-10-2013, 12:54 AM
I'm assuming this is the part of the engine that is closest to the rear bumper. If yes, this could be your #8 bearing outer seal and can repaired with the engine in the car.
You would need to remove the crankshaft pulley to get to this seal. It's about a $30 dollar part, but about 3 hours in labor....I think. It took me about 45 minutes to remove the crankshaft pulley on one of my diy jobs at home.
Check out our videos at P Fix It | Porsche 964 | Repair & Maintenance Videos, we may have a view of this on a preview video. PM me if you want to talk through the job and how to do it. Not that bad actually. You'll need a big torque wrench to torque the crankshaft bolt to the correct torque sequence.
Thank you,
dmark9
Old 12-17-2013, 08:58 PM
Tags
993 , crank seal , front main seal , oil leak
