1990 c2 intermittent loss of all functions
1990 c2 runs great, but intermittently will completely shutdown while driving, ie no headlights or hazards even, just completely dead. Thankfully it has come immediately back when driving. I can shut the car off after running normally and upon returning, everything is completely dead with no response from anything. Then after waiting a few minutes, everything operates as normal. Ive checked all the grounds and in dead condition I have power at the fuse block. In the dead condition, even the things that should work without the switch are dead with no response. Any ideas?
Old 04-29-2014, 05:37 AM
You can check the electrical part of the ignition switch as a starting point.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 04-29-2014, 08:40 AM
Battery cabling?
'90C4
Old 04-29-2014, 10:23 AM
+1 on battery cables. My 964 acted just this way ocassionally until it finally stopped and wouldn't come alive again. Problem was in the negative battery cable. Both cables looked perfect and the battery terminals were clean and bright, but when I removed the negative cable it measured about 1,000 ohms instead of zero like the positive cable. Less than $20 bought a good quality replacement at a NAPA store and all has been fine ever since.
Old 04-29-2014, 02:48 PM
It makes sense to me that if it was the ignition switch, then the lights and the flashers would still work in the dead condition. I ohmed out the negative battery cable and it was zero, but im replacing it anyway and keeping my fingers crossed. It may be that resistance builds up in the cable while in operation to produce the failure?
Old 04-29-2014, 06:10 PM
Raleigh993's Avatar
Make sure to check and clean your ground connections.
Old 04-30-2014, 06:00 AM
Also check the resistance of the positive battery cable and make sure that the smaller wires that attach at the battery terminal are clean and tight.
Old 04-30-2014, 02:19 PM
