964 clutch options and "while in there" items
Well, the time to drop the engine from my 964 Carrera 4 for the first time is here at last. I do not plan to rebuild the engine at this time as, other than some oil weeping, it is a phenomenal powerplant that does not need to be messed with. It still goes faster on the track than its driver is comfortable with, it idles well, etc. Maybe I can even fix the oil weeping while I'm at it, if it's something easy.
Right now I am researching, shopping, and budgeting. There are three basic questions here: 1. Which clutch setup should I get? 2. Should I replace the pressure plate and/or flywheel? 3. What else should I do while the engine is out? My primary rule whenever I do something on the car is to keep it legal for its PCA Club Racing stock class. I don't race but this seems like a good rule to keep from sliding all the way down the slippery slope. Relating to the flywheel and clutch, rule 1.L says that I can replace the DMF with a single-mass flywheel and that the clutch disk must be the stock diameter (which appears to be 240mm, am I right?). It goes on to suggest a 964 RS flywheel as a suitable replacement. Options abound. Some are easier to understand than others. The obvious choices are: a. Stock clutch disk is $176. Pressure plate is $593. DMF is $920. It's possible to just do the clutch disk, but my car has 164,000 miles on it and likely has the original DMF and pressure plate. Dropping the engine is a major chore on the C4. So I'm disinclined to just replace the disk and have to drop it again. b. Same as (a) but with a sportier clutch disk. Recommendations? c. Carrera Cup conversion kit is $2,079 plus a $450 performance chip to keep the idle stable. A lot of people say that you lose street drivability going this way. But how much do you lose? Is it harder to drive than with a nearly worn-out clutch disk? d. Centerforce clutch package from Pelican is $1,180. e. Patrick Motorsports has all sorts of parts. It looks like the starting point is a LWF at $535 plus conversion kit at $523 plus clutch disk of your choice plus a pressure plate of your choice, either the $1,060 sport/race version or the $598 lightweight/cup version. Then, the while I'm in there items. Here is my list so far: i. Replace gaskets on oil temperature switches, breather lid, oil temperature sensor, oil pressure sender, remote temperature sensor, and their 'lid' (perelet's oil leaks & fixes thread recommended items underneath the intake assembly) ii. Fuel injectors iii. Clutch master and slave cylinders and slave cylinder hydraulic hose iv. Ignition wires (anyone have experience with the $169 DIY kit sold by Pelican?) v. Engine sound pad (or just leave it out?) vi. Power steering belt (should have done it when I had the pump off to replace the seal where it meets the camshaft) vii. Distributor belt viii. A/C belt, which is nearly worn out and totally pointless since the A/C on the car doesn't really work; maybe just pull the A/C out of the car at this point? ix. Rebuilt alternator x. Rebuilt starter xi. Valve adjustment xii. Strip and refinish valve covers xiii. Strip and refinish engine cooling fan xiv. Engine carrier reinforcement xv. Engine mounts (Euro RS or is there a better option?) xvi. Transmission mounts (what exactly is required for this?) xvii. Strip and refinish engine tin xviii. Heater blower bypass xix. Clean out the engine bay from all of the years of spilled oil from the times I've removed the filter without puncturing it first, leaked oil from the breather area, road dust, and so on Anything inexpensive that I have forgotten? I'm not going to start buying parts or doing any work for a couple of months, but I want to know what I'm in for before I begin. Thanks! |
One more option Mid-Weight flywheel kits - Rennlist Discussion Forums
Thanks for the tip! That decides that issue.
And now I am thinking that it's a long winter and I am already removing the engine, so maybe a re-seal or even rebuild is not the worst idea. Does anyone have tips on the bill of materials to disassemble and reassemble the engine? The workshop manual says which parts should always be replaced, and then Pelican sells three gasket kits which appear to possibly (but maybe not, hard to tell) include all of those items. I don't want to buy two of anything if I can help it. Then I need to find a machine shop qualified to work on the various pieces of the engine. I'd be going at least 600 miles to get to one, I think, so I may as well ask here which shops do a good job for a fair price and are easy to work with remotely by shipping parts and talking on the phone or by e-mail about what is needed. Slippery slope...but the car deserves it, right? :) |
I don't think you exactly need the mid-weight flywheel.
I have a 996 GT3 RS clutch and lightweight flywheel (11lbs?). I do not have a chip. I don't have A/C either. Further the engine has been freshly tuned, ignition, ISV, all good. It takes a minute to balance out the idle when cold, but it hasn't stalled once. It sounds like you'll have a similar setup to me. If you end up needing a chip to prevent stalling, you get the benefit of the 'optimized' timings. |
Is the GT3 setup hard to adapt to the 964 engine and transmission? What parts are required to convert? Clutch, pressure plate, and flywheel or is there more to it? Thanks.
I think the clutch disk on mine is a 996 RS part number but the flywheel in the package is a 964 part and essentially everything else. Perhaps a more knowledgable member can confirm.
I just installed the mid weight setup on my car. It has a more mechanical feel than the old dual mass. No stalling issues but it does take more effort to depress the clutch pedal...not sure why that would be the case but I wish I could easily change the pedal effort.
Regarding the GT3 setup:
The Carrera Cup flywheel/clutch conversion kit that Pelican sells (PEL-FWC-C2C4N) consists of the following parts: 928.102.151.01.M260 flywheel bolt x 9 944.116.080.01.M38 release bearing 950.116.813.30.M157 guide tube 964.102.239.31.M157 flywheel 964.114.143.31.M260 ring gear 964.116.028.90.M38 pressure plate 900.067.103.01.M260 ring gear bolt x 9 996.116.015.32.M38 clutch disc 931.102.111.00.M34 pilot bearing If you tell Pelican you have a 2007 GT3RS and shop for clutch parts, you will find: 928.102.151.01.M260 flywheel bolt (same) 944.116.080.01.M38 release bearing (same) 964.102.239.31.M894 or .M157 flywheel (same) 950.116.813.30.M157 guide tube (same) 964.114.143.31.M260 ring gear (same) 996.116.027.51.M38 pressure plate (different) 900.067.103.01.M260 ring gear bolt (same) 996.116.015.32.M38 clutch disc (same) 931.102.111.00.M34 pilot bearing (same) So they really must not be that hard to match up if the only different part is the pressure plate. Regarding the midweight setup: I'm glad to hear from someone actually driving with this. Did you notice any difference in throttle response? |
All the g50 clutches are interchangeable after about 1990. The lightweight flywheel must be matched to a sprung hub disc and matching TOB,while the DMF one is solid hub(the torsion is taken up by the rubber in the DMF.)but the pressure plates are the same dimensions and interchangeable.The GT3 RS clutch springs are about 30% stiffer than the std 964 one .The 993 standard PP is about 10% stiffer than the 964 and equal or very close to the 964RS one.
I recall reading The clubsport 993 in Europe uses the stock 993 PP but the SMF combo otherwise. I wouldn,t use a turbo or GT3 PP unless you have a very strong left leg and need the extra clamping power. The std setup can last 100,000 mi so it is usually adequate. For street use aside from the possible stalling issues with a LWF the biggest annoyance is the gear rattle you hear below about 3000RPM. Andreas ? something posted a pressure plate list on Rennlist I found several years ago If upgrading for the street I would use a std 993 replacement set in a 964 ,same disc slightly stiffer PP |
After some delay (new garage finally got doors and then it was cold; finally got some heat and maybe even some time to work), the car is up on jack stands and the oil is drained. I pulled the fuel pump fuse to kill the engine before draining the oil, so the fuel lines should not have much or any pressure. Disconnected the battery and started on the engine drop process.
Note on the pressure plate: The 993 Euro RS part number is the same as Pelican sends with the 964 Carrera Cup kit. So that seems like a very reasonable choice. So here's the question: When I drop the engine, is there any reason to (or not to) remove the heat exchangers first? I'll be working on jack stands and I have an ATV jack to lower the engine. I've removed the heat exchangers a couple times before, so I know it's not hard to do. The question is if it gains (or loses) anything in the engine removal process. |
the 993RS used the same dual mass flywheel and clutch as the regular 993s The 993RS/CS and 993 Cup used the 964RS/Cup single mass flywheel and spring centered clutch that you want to use, My memory is fading but I seem to recall that early 964C4 also used this setup but I could be misremembering. The exhaust is usually left on for most drops |
Bill: Thanks for the response. I'm looking at the equivalent of the Pelican Carrera Cup conversion kit, although from separate parts since there are a couple of options to save some money by getting a different brand from what comes in the kit.
It is indeed comprehensive, but with over 160,000 miles on the car and an unknown history prior to about 140,000 miles I have no shame in replacing more of the clutch mechanism than needed. I'll be doing the clutch slave cylinder and fluid hose and a couple other items while I have the car apart. My 'optional' list runs from new engine mounts up to a total rebuild depending on whether I can figure out how to put the latter on my 1040 Schedule A. It sounds like the 993 RS pressure plate must work the same with a DMF as with a SMF. I know that the 1989 Carrera 4 was different from the later version but I don't know the exact differences. it certainly could be as you suggested. I have a 1990 so, barring any surprises when I separate the engine and transmission, I ought to have the DMF setup. How much of the exhaust should be left on? It seems to me that removing the secondary muffler and catalytic converter should provide clearance for the engine to drop, leaving the primary muffler (or in my case the bypass) in the car unless it and the bumper need to come out for clearance. |
Also take a long hard look at the clutch release arm, the bushings tend to go at awkward times and will do a lot of damage when they fail. I replaced mine w/ a 997 GT3Cup part, 997.116.086.90 You can't use the 993RS dual mass parts w/ single mass parts, they are incompatible. You have to go all one or the other. It's possible that they just mislabeled it as RS when it should be RS/CS or Cup, most of these parts have been superseded w/ 997GT3RS parts anyway |
Thanks for the tip. Does the pressure plate really change between the SMF and DMF setups? Pelican's item number for the kit is PEL-FWC-C2C4N. The pressure plate included is part 964-116-028-090-M38. The PET lists this as the normal part number for 92- and an alternative part for -91 cars. Or I could be the victim of my own misunderstanding or a catalog error.
This is a SMF clutch disk from a 993RS/CS http://forums.pelicanparts.com/uploa...1423000480.jpg This is a 996DMF setup 964/993 would be similar http://i275.photobucket.com/albums/j...sclutchkit.jpg |
I know that the single-mass flywheel requires a spring-dampened clutch disc while the dual-mass flywheel requires an undampened clutch disc. Can you help me understand the difference in the pressure plate?
the 993tt and 997GT3RS have greater clamping force and can be used too |
Thanks - I thought I was losing my mind for a moment there. :)
Any experience with those parts? I don't think my little 964 will ever put out such torque as to benefit from greater clamping force than it already has. Or, at least, the cost of modifying the engine to reach that level of torque would make a GT3RS pressure plate a drop in the bucket. But the GT3RS part seems to cost the same or even a few dollars less than the 964 Cup part, so unless we're talking about the pedal effort difference being enough to make my left leg disproportionately hefty, I could just as well go with the upgraded one. That's the problem with these cars. There are too many possibilities for anyone to have tried them all. Except maybe Bill Verburg. Thanks again for weighing in on this one, Bill. :) |
Ari, over Christmas holidays I dropped my engine to do minor here and there. Then right before I put it back I went to adjust valves and discovered that I have broken head bolt (<<<<--- check yours). Minor drop converted to major fun.
Things that you list all make sense. Do allow for s%^&t to happen. I'll do complete writeup once I put car together, here are few notes. 1. Leave heat exchangers on (you can keep whole exhaust): https://dl.dropboxusercontent.com/u/...d/IMG_0098.jpg 2. To do clutch etc all you need is ATV jack and few floor jacks: https://dl.dropboxusercontent.com/u/...d/IMG_0168.jpg you'll have access to pretty much everything except exhaust side, you can do exhaust gaskets etc when you'll put it back in the car. 3. If s%^&t will happen. You'll need engine lift and yoke and more deliberate tools: https://dl.dropboxusercontent.com/u/...d/IMG_0360.jpg 4. Depending on level of s%^&t you'll end up taking many pieces apart, I ended up here: https://dl.dropboxusercontent.com/u/...d/IMG_0545.jpg https://dl.dropboxusercontent.com/u/...d/IMG_0514.jpg Important notes: 1. Read factory manual 1st 2. See #1 3. You can read internet after you do #1 Measure everything. Compare to factory specs. I have 78K miles on my car, you have 2x more - some things may be worn and need replacement. |
Oleg: Thanks. I am definitely allowing for everything to go wrong. I've run a budget for a complete rebuild of the engine and, while I don't know if it's a pill I WANT to swallow, I know that if I have to I CAN swallow it. I adjusted valves not that long ago (while following your other advice to fix numerous oil leaks, although there are a few stragglers, probably from the breather or the through-bolts) and the studs were all okay, but I don't want to make any assumptions and will check everything I have access to.
I didn't have the energy in me to pull off enough junk to access the spark plugs and do a leak-down test while the engine was still warm. So I'll do that when it's cold. The PPI leak-down I had done indicated all signs good except some leakage (12 or 14%) on cylinder #4, which they didn't bother to identify as being through the rings or one of the valves. So I'll be watching for that. It's possible that just being driven for the 4 years since then will have tightened that cylinder up--but equally possible that it's now looser along with its friends and neighbors. So we'll see where the numbers are and where the air is going and decide whether and how far to rebuild. It appears that you're just doing a top-end rebuild. How did you decide to do that? It seems to me like the top is the expensive half of the rebuild, so if you go that far it is not much more expensive or time-consuming to split the case. But I'm a complete novice and would really like to understand your thought process. I'm trying to remain positive and conservative at the same time. It probably comes across as passive-aggressive: Just the clutch one day, total overhaul the next. But that's how it goes with a Porsche, it seems. |
That said once I took it apart - cylinders still have honing marks, valve play is well within spec. Clutch thickness is also within spec. Based on what I see . If you have well documented car, had it for several years, your engine has less tan 200k miles and has no visible signs - do not take engine apart. Oleg. |
Not trying to hijack a thread. But I hope your right Oleg? I just dropped my 95 993 for clutch/flywheel. At 126k choosing not to do top end. I've not done a leak down and it's leaking oil so bad now that consumption is questionable. It didn't us oil before so no top end.
No worries about thread jacking. Adds to my knowledge too.
I am progressing on the engine drop. The manual says to disconnect cable terminal 30 from starter (in addition to the ground strap to the body). Does anyone know where this terminal 30 can be found? Also, what size socket do I need to use on the clutch slave cylinder? It's a tight space and I would rather get a hint than bust my knuckles trying to reach in repeatedly with different sockets. Next up, some have said that you can disconnect the throttle cable at the throttle body. I did that, but it appears to be fixed through a bracket that is attached to the engine. Is this going to work or should I just go back to the workshop manual method of pulling the cable out to the rear and leaving it attached to the engine? Pro tip: People say to use a 19mm ratcheting wrench to remove the top bolts connecting the central tube to the transmission. This is correct advice. What they forget to mention is that the complete set of GearWrenches you just bought only goes up to 18mm. |
I disconnected wires going to the battery /ground strap to body. Slave cylinder is a 13mm. ( I had to use regular box end. Gear wrench was too fat ). I tried pulling throttle cable from peddle but it got hung up @ about 2ft. So I dropped the engine a bit and disconnected at engine and fed cable back through after pulling grommets.
Thanks... It's hard to see all the wires on the starter, unfortunately, and I've never held one in my hands so I don't know which wire is which. Does anyone have an idiotproof diagram handy? :)
Another question: Does the pressure plate / flywheel assembly have to be balanced as a unit or is it safe to piece them together? If balancing is necessary then it changes my vendor options quite a bit, unless the local tire shop can balance the assembly for me which I haven't called to ask yet.
My stock setup lasted 110,000 mi so unless you need the extra clamping because you are turbo or supercharging it I wouldn,t bother. Your left leg will never forgive you if you do. |
If you do decide to rebalance it a tire shop can,t help you .Engine rebuilders will either have the equipment or will send out the components for you to someone. |
Just so I understand clearly: A fresh pressure plate should be balanced from the factory, and a fresh flywheel should also be balanced from the factory, so they do not need to be balanced together unless I have some special needs?
In other news, a couple of items have come up while working on dropping the engine. The starter is still completely foreign to me. It seems like it was deliberately designed to be impossible to disconnect while it's in the car. Does it become easier after the engine is lowered a couple of inches or should I keep hacking away at it now while the engine and transmission are safely secured to the car? Does anyone have a good picture showing precisely which fasteners need to be undone? The other one is the longitudinal slave cylinder. The small allen-head bolt rounded out for me so I had to use an Irwin Bolt-Grip stuck bolt extractor. Fortunately I had one the right side. But the "lock" that supposedly slides right out seems to be firmly planted and there isn't any obvious way to grab it and pull. Are there any tricks here? The clutch slave cylinder is also deliberately designed to be impossible to work on, as I already knew from experience bleeding it. But removing it is even harder. I got the lower nut loose but the upper one is just impossible to reach with a wrench unless you have longer arms even than I do (mine are not exactly short). I decided that I can probably get a better angle on it once the engine is lowered a couple of inches. If anyone knows of why this is a bad plan, please speak now or forever hold your peace. (Or at least don't laugh at me when I come back later and say how I learned it is a bad idea.) Okay, that's it for today. If I can get the longitudinal lock's "lock" out and the starter properly disconnected, I can start to lower the darn thing at long last. Thanks again! |
Update: The yellow wire on the starter solenoid was being stubborn because the whole bolt was turning. Once I held the lower nut still and got the upper nut loose, it came right off. The starter now appears to be free. I was able to torch and then cold-chisel the PDAS longitudinal lock's locking key out to an angle I could pull it free with a vice grip. And I got the clutch slave cylinder out with all my knuckles intact.
The remaining complication is the longitudinal slave cylinder fluid line. The instructions both in the workshop manual and in every other source say to lay it to the side to the line clears the transmission. However, the route of the hard line makes this seem impossible. The slave is forward of the transmission mount cross-member. The hard fluid line runs above the cross-member / below the transmission and then to the bracket where it attaches to a flexible line (as does the transverse lock's fluid line). What "route" do people take to get the lock clear of the transmission so you can lower it? |
Success! Obligatory photo in engine bay. I'm not necessarily proud of how I came out of the process, but this photo does two things: (a) induct me into an elite group of Porsche owners and, more importantly, (b) remind me to wash my face before I go to bed so my wife doesn't kill me in the morning.
http://theari.com/~ari/enginebay.jpg If it helps anyone in the future, the PDAS longitudinal slave cylinder solution (regarding my previous post in this thread) was this: Disconnect transmission cross member and lower it 1 inch, then pull the hard line out toward the driver/left side of the car until it clears the cross member and can be moved freely beneath it, and then it was possible to tie it out of the way. Tips on the final step of lowering the engine: Watch the axles very carefully as you lower the engine. I went slowly, an inch at a time, but somehow didn't see them catch (especially on the passenger/right side of the car where the starter interferes with it). The steel wire I had used to hold them in place broke and I had to wiggle the engine/transmission assembly side-to-side a few inches in order to get the axles to clear it again. Lightweight steel wire is probably insufficient to hold the central tube. I used two strands, tied off and bolted down to the central tube cover studs (just like you would with the self-made tool that the workshop manual calls for). One broke, quite likely due to the weight of the transmission bearing down on it in addition to the central tube. The other remained intact the brief moment it was stressed later in the process but mostly I ended up bracing the central tube with a jack stand and a big chunk of wood to make up the difference. Be careful that the wiring harness on the top center of the engine is pulling cleanly through and not pulling against the little plastic bracket that holds it against the front of the engine bay. Be very careful if you have to jack up the car while the engine is not mated to it. It does not behave the same as it does when the engine is part of its mass, which may result in it handling differently than you are used to. Even with the rear bumper off, I had to get about 3 more inches of clearance to get the engine out of the car. The problem was that the ATV jack I used could not go high enough to reach the engine when the car was sitting on my jack stands (the flat top kind that Pelican sells, set to the tallest position), so I used a couple of layers of dimensional lumber between the jack and the engine. Thus, it did not get all the way down to the lowest point on the jack. I used a normal jack on a rear suspension member to lift the car up, but it twisted slightly on the front jack stands as the jack lifted and pulled it toward me slightly. This made me extremely nervous. I could have alleviated this effect by sweeping the garage floor perfectly clean around the jack before lifting the car, as the jack then would likely have rolled more freely on the floor and put less rearward force on the car (rearward on the jack = sideways on the car). I got ambitious and tried to split the engine and transmission. I got the starter off, but need to get ahold of a long M6 bolt in order to remove the release fork shaft. This step in the manual is not explained very clearly and I briefly sang the Previous Owner Blues because I thought there was a bolt missing from the car. :) Now, for a weird one. There was a whole mess of zip-ties holding some wires to various parts of the car, which I had to clip as I lowered the engine/transmission assembly. There are two rectangular blocks that appear not to have any labels, which were bolted (by a little angle bracket on each of them) to the mounting bracket that holds the fluid lines for the PDAS locks to the transmission. They each have two wires coming from them, and the wires then seem to be joined together (I don't remember sitting here in the warm house if they were in parallel or series) and go to a cylinder. The cylinder appears to be a capacitor of some sort, labeled COMPUTAMER with some handwritten numbers and preprinted MFD and VDC. If the numbers written on it are to be trusted, it's a 25VDC / 42,000 MFD capacitor. This is then wired in with the starter from the appearance of it. It is permanently connected to the wiring harness on the engine side of things. I don't know what kind of connection was made as I did not yet remove the mass of black electrical tape that is protecting it. By all appearances, this entire clump of wires and parts is aftermarket. Does anyone know what its purpose might be and whether it is a useful modification? Or should I just hack it off and return my wiring to stock? |
Scraping off dust and grime, I found that the label on the capacitor is COMPUTAMITE and that the two bricks are Alternator Noise Suppressor, Model No. ANS-80 from Pacific Accessory Corporation in Santa Ana, California. They are wired in parallel with each other, and in series between the capacitor and the alternator. The other end of the capacitor was wired to the starter.
Here is a diagram I found online for the ANS-80: http://pix.crutchfield.com/manuals/127/127ans80.pdf Note that it's hosted by Crutchfield, which implies that this whole setup is audio-related. The car had an aftermarket stereo head unit when I bought it. There are a few stray speaker wires that make me suspect that a subwoofer had been mounted in the car and removed before I bought it, in all likelihood before the previous owner bought it. I have since put in a nicer head unit but I don't bother with subwoofers and all that jazz. This car is made for driving and, when you're driving it properly, the stereo is kind of overwhelmed by the engine noise. Doubly so if I bypass what's left of the exhaust. :) So I am tempted to ditch this contraption, but don't want to screw up the big red wire from the alternator. I'll have to take a look at the factory wiring diagram and the usable length of wire from where this mess was spliced in to see if I will have to do a new splice or just solder a new ring connector on the end. |
Ran into one more pair of stubborn fasteners: the TOB guide tube screws attaching it to the transmission. I've applied an impact screwdriver, a night of PB blaster, and some time with a torch to no avail. I don't suppose anyone has a trick other than drilling them out that I can try.
If you haven,t peeled out the center of the screws with your impact screwdriver yet, you need to hit it a bit harder. The screws should come out BUT be prepared to ruin them in the process.
(also make double sure the impact driver is set on counter clockwise) |
I got them out. I need up drilling and using the spiral screw extractor on them. Someday, I will buy a better impact screwdriver. Mine is a Harbor Freight tool and the rubber handle is a little sloppy to get anything done. That said, it was handy for the pressure plate bolts. Two of those got a little rounded out because I didn't clean them out enough before trying to remove them. The tool has a 1/2" drive head so I was able to out the triple square socket on it and hammer enough to break the bolt loose.
Today's challenge: I am going to replace the flywheel seal. This was a good idea before, but now that I have begun to try to get the old one out, it's an even better idea. Any secrets to success here? |
Wow, just read through the last few entries. I think that everyone goes through all of these exact issues. :)
Flywheel / rear main seal is easy. Just insert the new one so that it's flush. I dunk these kinds of oil seals in fresh oil so that they go in easier, and without tearing. Impact screwdriver is exactly the right tool for the guide tube screws. And the correct size phillips bit. Pulling the old guide tube seal out is a pain too. I poked a couple small holes around the circumference, then used two L-shaped dental picks into the holes to tug it out. New one presses in easily. Pressure plate bolts have a pretty shallow head. Easy to strip them out. Definitely want to replace all of them with new. Have fun :) |
Getting the seal in sounds easy. Getting the old one out has been my trouble. I put a screw into it and pried out--just to pull the screw through the seal. I am tempted to start a total overhaul just to get to the darn thing. I did get replacement pressure plate and flywheel bolts, not to mention axle-to-transmission bolts and a few other replacement fasteners for those stubborn ones that suffered any damage or required any heat to come out. Glad to know I'm not the first to sail these rough waters. It's definitely fun overall, but driving the car more is the real fun part I'm working toward!
Try something like this to pull the seal-
Sears.com Two of the right-angle hooks in a hole punched into the seal, should be enough to wiggle it. Anything similar should work. The clutch fork rod was my personal favorite. Took me hours to pull that $%^ out! |
I actually bought the same set of picks from a different brand at a tool store this weekend. I will try to get two at 180-degree angles to each other and wiggle the seal. Just one of them didn't do the job. Thanks for the tip.
The clutch fork shaft wasn't so bad for me, once I figured out that the proper tool is a bolt. Porsche is so unpredictable in the workshop manual. A 10mm allen socket is a "special tool" but an M6 bolt is normally in your toolbox? It's turned out to be harder than anticipated to find a ring terminal that fits on the alternator wire. The O'Reillys, Sears, and hardware stores I've looked in have all come up short with the largest-gauge ring terminals in stock being 10-12awg. I estimate that the alternator wire is a 2awg. I don't want to put all that 1990-era aftermarket stereo junk back in the car with the engine. |
