A/C Service Help
Hey guys. hoping to get some quick opinions. When i bought my car the A/C wasn't working....Tank was empty and needs to be converted to R134. Now the car is at the shop and the tech reported the following:
So, basically, they're recommending a retrofit plus replacing both the condenser and compressor since they have signs of leaking. My thinking would be to convert first and monitor the system before replacing. Any thoughts would be helpful since the compressor ($400) and condenser ($200) aint cheap. Thanks! |
Take it to an non-Porsche A/C certified shop (different one), instruct them that you want to convert to R-134a (<$200). Do NOT tell the new shop anything of the above.
normally the 964 leaks occur in the evaporator not the condenser. You need to evacuate and recharge with full load of r12 and have them take a sniffer to find the leaks.
I would not convert to r134 until I found the leaks.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
