964 C4 Instrument Cluster
Does the C4 cluster have a CEL?
Old 05-04-2015, 12:13 PM
Let me expand on this - failed smog check in CA due to CEL not lighting up when key is switched to first position. The manual does not show a CEL but, the cluster does have one - is it possible that this is a C2 cluster?
Old 05-04-2015, 01:17 PM
CA SMOG - Page 2 - Rennlist Discussion Forums
Old 05-12-2015, 06:28 PM
Took it to TLG Auto in North Hollywood and found that my 90 has a factory plug in the CEL spot meaning that it wasn't intended to have one. However, swapped a bulb for the plug and the CEL works properly.
Old 05-12-2015, 06:29 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
The first 964 didn't have the CEL installed. It was introduced in the 90' model lineup. The 89' did not have the light but as you did you can easily retrofit it by adding the bulb.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-21-2015, 08:50 AM
