BBi Autosport Lightweight 3.8 Liter Engine Build for Magnus Walker's 964 Project
BBi Autosport Lightweight 3.8 Liter Engine Build for Magnus Walker's Latest 964 Project
Modern Performance Meets Old School Restoration
BBi Autosport is excited to announce that air-cooled Porsche builder/collector Magnus Walker commissioned us to build a lightweight 3.8 liter engine for his latest Porsche 964 project. Based off a 993 engine, here are some quick specifications below and please stay tuned for updates!
  • MAHLE 109mm Cylinder Sleeve 102mm Bore Pistons 109mm O.D. Cylinder
  • BBi Cup Spec Rods by Carrillo
  • Knife Edged &Balanced Crank
  • BBi Spec Heads w/ Aasco valves
  • Titanium Retainer for Lightweight Valve Contro
  • Porsche 993 RSR cams
  • Rothsport 48mm Individual Throttle Bodies
  • Porsche 996 GT3 Cup Intake Manifold
  • MoTeC M48 ECU
  • Rothsport Headers
  • Rothsport Wiring Harness
- Jerry@BBiAutosport.com
Old 10-29-2015, 01:57 PM
Bill Verburg's Avatar
  • MoTeC M48 ECU
  • Rothsport Headers
Sounds like a nice motor
Mahle doesn't supply the tapered l/w wristpins anymore?
what crank? 993? GT3?
Bill Verburg
Old 10-29-2015, 03:47 PM
Bill, Thank you for the kind words! We used the 993 crank and I will have to discuss with our engine department staff about the wrist pins.
Old 11-10-2015, 12:57 PM
We are making good progress on the engine and the car will debut at the Los Angeles Auto Show on November 20th. Here are many more pictures of the engine assembly process:
Engine case thoroughly cleaned in the ultrasonic cleaner
Balancing an engine is a critical step at BBi Autosport. For this particular engine, the components are weighed and matched within 0.3 gram. In comparison, factory tolerance is approximately within 5 grams.
Old 11-10-2015, 01:04 PM
Old 11-10-2015, 01:16 PM
Old 11-10-2015, 01:17 PM
Old 11-10-2015, 01:18 PM
Old 11-10-2015, 01:19 PM
Old 11-10-2015, 01:20 PM
Rothsport Individual Throttle Bodies Installed
Old 11-10-2015, 02:30 PM
Old 11-10-2015, 02:31 PM
I am fu~~~~ jealous it not goung in my 91 964
Old 11-10-2015, 03:32 PM
Cemoto's Avatar
Motor porn.
Al
Old 11-10-2015, 04:05 PM
I would rather be driving
jpnovak's Avatar
Nice and Tidy.
Why are you using collapsible oil return tubes on a fresh engine build?
Old 11-11-2015, 10:01 AM
rsscotty's Avatar
The specs in the original post states "M48" Motec ECU........it should say M84....there is a big difference since the M48 was old school technology.
Old 11-11-2015, 02:00 PM
Skunk works
JV911SYDNEY's Avatar
Confirmed on rennlist that it is actually the M48
964 RS-4
Old 11-11-2015, 04:05 PM
Originally Posted by jpnovak View Post
Nice and Tidy.
We used it mainly for aesthetics.
My apologies for the misinformation
We are using the M84 for this build
Old 11-11-2015, 04:12 PM
Skunk works
Well, there you go. Same as what I'm using
964 RS-4
Old 11-12-2015, 02:48 PM
It appears in the pictures of the Rods that there is metal removed on the beam near crank pin and below the wist pin along the axis of the beam and it also appears that the metal removal left a rough cut by the end mill and has not been shot peened to reduced the stress imparted by the cutter.
Is this the way Carrillo has been producing these parts?
Or is it just the Picture?
Regards
Old 11-12-2015, 07:36 PM
