91 Carrera 2 Tiptronic in limp mode.
Hi Guys ,
I need your help . My friends 964 is stuck in limp mode. We were able to use the Durametric Diagnosis scanner and this were the findings:
Code 23 - change of ignition timing
Code 32 - solenoid valve 2
Code 50- unknown fault code.
Does somebody here have an electrical wiring diagram for a 91 964 Tiptronic? I cant find it in the web. . I found one but the print was'nt big enough.
Thanks in advance,
Tdh888
Old 01-11-2016, 12:49 AM
porsche964guy's Avatar
My tip goes in Limp mode once in awhile before. I found that if i shut it off and tap the control switch in the kick panel next to my left foot (left hand drive) and restarted everything went OK. Later after close examination found some wires in the plug were bare and shorting out. Taped them up and no problem since.
Old 01-15-2016, 03:51 PM
what happens after you reset the tip with the durametric?
Old 01-15-2016, 11:53 PM
