Looking for info on 964 C4 rally conversion
Hello
I'm looking for some more information on how to convert a 964 Carrera 4 to a real rally car...
What to do with suspension, gearbox, front diff, etc...
Thanks.
Old 02-01-2013, 10:21 AM
Nobody?
Old 02-03-2013, 10:55 AM
I think it's probably too much money for most sane people. The initial conversion wouldn't be horrible, but the maintenance expense on a 964 C4 used under such conditions could be extreme.
'90C4
Old 02-03-2013, 11:00 AM
Let's get some info. I'd build one as well. Cool idea
Old 02-04-2013, 07:44 PM
I thought a 964 C4 rallycar was popular in US...
Old 02-12-2013, 02:33 PM
Bill Verburg's Avatar
They only built 22 of them, i have only seen 1
Bill Verburg
Old 02-12-2013, 03:13 PM
Bill Verburg
Old 02-12-2013, 03:14 PM
gearhead
Doesn't Jeff Zwart own one of them?
The rally gear ratios made for those C4 lightweights are über rare.
From a cost, reliability and performance standpoint I would seriously consider converting it over to a 993 C4 gearbox.
Old 02-12-2013, 06:37 PM
Those cars are so rare and valuable unmolested that you'd be nuts to modify one.
But I've consulted w/ guys that took pristine 993RS's and modified them too.
Modifying a belly button car is one thing but modifying the specials is another
As far as I recall, Ruf has/had the the parts on the shelf to add the manual locks/adjustments to the 964 driveline
Bill Verburg
Old 02-13-2013, 04:53 AM
Too much money, especially when you can get solid STi subarus for $25k.
'90C4
Old 02-13-2013, 05:11 AM
Series900's Avatar
This one is for sale, I built it off a 94 C4. and today marks Celebratory post #959
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 03-07-2013, 02:38 PM
German Aut0haus
B. Elliott's Avatar
I've always wondered. On cars where the heater ducting is removed, why have an open area between the fan and the case, and not have it sealed off to help force more air down over the engine?
'90 964 C4
Old 03-07-2013, 03:47 PM
more is not always better, the cooling system was designed to have x amount of air bled off through the heating system, whether it is routed to the cabin is irrelevant, heated air is always bled off and either used in the cabin or dumped beneath the car.
with no cabin heat setup the excess air still needs to be bled off
Bill Verburg
Old 03-07-2013, 03:58 PM
The C4 lightweight is really unique and too expensive to use.
I was thinking of building a 964 for rallying in Belgium. Doesn't have to be a C4, a C2 can also be good. In 2012 I was vice champion in historic rally with a 1973 RSR conversion, so I'm used driving a RWD car.
So info on any 964 rally car would be nice. If someone knows something for sale, please let me know.
Old 03-11-2013, 04:21 PM
I think that the only difference between 964C4 and 964 C4 lightweight is the ring&pinion (8:37) F&R, not the gear ratios
Ciao
Paolo
Old 03-24-2013, 11:38 AM
Did Anyone Complete RALLY SAFARI Build?
I am building a safari/rally car out of a 964 C4 and the bulk of my questions surround specing-out the suspension for this build. -- ANYONE?
Old 02-22-2017, 09:49 AM
check out these guys, you may have do scroll down a bit but they are doing it
https://www.facebook.com/search/top/?q=rothsport%20racing
Old 02-22-2017, 10:12 AM
