KYUKYU3
samurai_k's Avatar
How do you know know if ball joint is bad
Hi,
I'm starting a suspension update and replacing what is needed in my 110k driver.
My control arms are out right now as I am replacing the bushings as they were cracked and caused noticable play in the control arm and a 55mph shimmy.
I tried to articulate the joint in circles and the action is smooth and firm. The are a bit stiff though as I have some new tie rods from elephant racing as a comparison which are smooth and firm too but are slightly easier to articulate.
How do I know if a ball joint is ok or needs replacements? Visually the boot on the old ball joints are good. Is it ok I can inject some grease in the joint to repack them?
Thanks!
Sent from my Pixel XL using Tapatalk
Old 09-08-2017, 06:41 AM
Newsboy's Avatar
I usually check by rocking the tires back and forth to check for play. Since you have them off the car,
not sure how you could check? Here is a link, if you want to replace them.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Old 09-09-2017, 03:37 AM
Newsboy's Avatar
Use the link in the post above, and search for ball joints.
Old 09-09-2017, 03:39 AM
Easiest way is to jack up that corner of the car enough to get a long pry bar under the tire and lever up the tire to see if you can make it move or klunk. It is easier IMHO to check it on the car.
2010 987.2 midnight blue - SOLD
I make custom engine harness for your 914-6 conversion
'91 964 Targa guards red, cashmere - SOLD
several 914's and loads of parts
Old 09-11-2017, 05:51 AM
Location: behind the redwood curtain, (humboldt county) california
Do it.
I replaced a totally trashed stock Volvo ball joint that took out a new michelin tire with only 3000 miles and had huge play. My wife's car had 118,000 miles itTML][/HTML]
If the arm is off the car, just replace the bushings and the ball joint.
No worries,
Chris
Old 09-22-2017, 09:39 PM
