89 C4 964 start up issues
Hi All,
awesome forum first time here looking for some help. my 89 model c4 964 gives me trouble starting after a drive and sitting for 30mins and over. will never start with first ignition cranking but 99% of time will start with 2nd time around. if I turn car off after drive and start within a few moments or so never a problem. only after been sitting. also generally starts o first time cranking on cold start sometimes does need 2nd time though. once car running its randomly and ever so slightly hunts at idle. drives like a dream any advice or help appreciated cheers jad |
Was having a similar problem. I installed a new DME relay, and the problem was fixed.
Hook up a fuel pressure tester and check fuel pressure during cranking, while running and after shutting off. Post results.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
