Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
camdon's Avatar
996tt rear spoiler issues
One side gets caught up a little and gets stuck. Then the dash light does on. There is fluid on the one ram. Does this mean a complete rebuild to make work properly again?
A few P-cars in the garage
Old 08-18-2018, 10:31 AM
camdon's Avatar
Any help?
Old 08-19-2018, 06:15 PM
i tried to repair mine
it worked for two more weeks then I bit the bullet and replaced it
parts cost my mechanic almost $2000
Old 08-19-2018, 06:40 PM
camdon's Avatar
What was yours doing or not doing? What repairs did you make?
Old 08-19-2018, 06:57 PM
Same as yours
it was sticking on one side
we changed O rings and that did work but after two weeks it started doing it again
so I bought an entire new assembly
Old 08-20-2018, 07:36 AM
camdon's Avatar
Same as yours
Going to give that a try. Thanks
Old 08-20-2018, 07:07 PM
FPB111's Avatar
E-ram replacement
https://rennkit.com/product-info/996turbo-eram/
UMW Ultimate Motor Werks also has a fix
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 08-25-2018, 07:08 PM
Originally Posted by FPB111 View Post
I’ll throw in a 10% discount! Email me at djcooper@rennkit.com
Old 09-14-2018, 03:26 AM
Just had the wing motor replaced on the '15 911 under warranty. It was parking a bit cock-eyed and the panel gap on the RH side was way off. Tech said there was a spring that breaks in the motor mechanism causing it to not retract properly. Dealer fix to replace the motor was $3500, cheerfully covered under CPO warranty. Somewhat common problem I'm told.
Old 09-16-2018, 08:58 PM
we have sold our eRam Kit to a few dealers. Far less expensive than the dealer, with about 70% of our kits installed DIY. Pelican recently contacted us, now they offer our products: https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=Rennkit
Old 02-16-2020, 06:52 PM
I just purchased a 2002 Porsche 911 Turbo, knowing it had a spoiler issue that needed to be resolved. I'll probably go with the Rennkit option (once I refill the bank account) but was wondering if I can disable the "auto-deploy at 70+ mph" feature as a short-term option to eliminate the fault warning light? I don't plan to track the car, so most driving will be close to speed limits...
Old 12-20-2022, 08:17 AM
I don't think you can disable the auto deploy in order to eliminate the fault warning light as not having the spoiler deployed at speed is a safety issue. I realize it is a real nuisance to have any fault light on. Repairing the spoiler can be DIY, but you have to take the spoiler apart and the 7 clips that hold the lower edge of the rubber bellows will need to be replaced. Putting them back on is a minor pain in the ass. The Rennkit option may be a simpler solution. Congrats on the new wheels. If my 996 were a turbo, it would be a widow maker.
Old 12-20-2022, 03:42 PM
