Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
rear end noise
when coasting to a stop, (2000 996 ) in or out of gear i get a distinctive noise from rear that slows or speeds up as wheel speed changes.....it's not a very mechanical sound, rather like a flat spotted tire or something......I can't hear it when going above 20 miles an hour, probably due to increased wheel speed and engine noise...any ideas would be helpful
Old 03-17-2019, 10:51 AM
Check the fluid level.
Find a parking lot, drive both directions in a circle, coasting, see if you can isolate noise one side or the other. That might indicate a wheel bearing. Use the brakes/e-brake on and off when coasting. Might also be a brake issue
Old 03-22-2019, 09:33 PM
If the tread is causing the noise you should be able to feel the tread flaw with your hand.
Old 03-24-2019, 02:16 PM
Tags
rear end noise
