Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
alternator problem
when my battery is fully charged and the engine is cold the alternator is putting out 14.2 volts. As the car is driven and the temp goes up the output of the alternator goes down to about 13 volts and the battery loses charge.....any idea where the fault lies???????
Old 05-26-2019, 01:11 PM
Science is NOT optional
rbogh901's Avatar
thinking the y cable is one place to check. let us know what you find.
PCA member since 1993
Old 05-29-2019, 04:29 PM
I second the y cable. I just replaced one today that was corroded.
Old 05-29-2019, 08:21 PM
JFP in PA's Avatar
I wouldn't be replacing anything until you run voltage drop tests to make sure it is the cable. If the cables are OK, I would check the voltage regulator.
Accrochez-vous bien de vos rêves..........."
Old 05-30-2019, 07:22 AM
