Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
What's the protocol for a 996 turbo front corner coolant dribble?
The front corner of my 2001 996 Turbo has a slight dribble of coolant after / while driving. My car has the leaf grilles fitted and no build-up there so I'm not so much expecting a corroded radiator (also air con is very effective), rather I understand the coolant hoses have crimped ends which come slightly loose due to age-related shrinking of the rubber.
I've a mechanic coming tomorrow to sort it out for me. What's the process here for sorting this?
So I'm expecting the protocol is as follows:
Get car good and hot
Remove front bumpers
Get access to the radiator
Run engine & inspect for leak
If hose, remove hose & take to local hydraulic company to re-crimp the end
If radiator, order radiator, reassemble car and use until parts arrive.
Is that about right?
Is there anything else I should be mindful of or that I ought to do, such as e.g. to not lose too much coolant and to not create airlocks?
Is it a straightforward case of reassemble, fill with coolant and off you go - or does the gas need vacuuming out or some other procedure?
Old 11-02-2021, 03:42 AM
Cars are for driving
I always vacuum fill. Also, if it's leaking any kind of quantity of coolant, you'll see the residue. Pressure testing the radiator, negative or positive can confirm even small leaks.
Old 11-03-2021, 09:20 AM
Tags
996 turbo , coolant , leak , radiator , turbo
