996 engine drop
Hi all I have a 996 on 02 plate cabrio tiptronic am trying to lower the engine so i can remove coolent resorvoir so as to get to the AOS at the back Lowering the engine drops to the right but barely enough on the left where the coolent bottle is. wonder if it is the drive shaft needs turning or is it something else the issue if any. Any insight from anyone who experienced this .cheers
Remove the long bolts through the engine mounts. Remove the large coolant hoses.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
coolent hose
thanks for that info will need to remove the coolent hose and bolts are already off
will let you know soon. |
Of course, support the engine via the sump cover area (that's been protected with a wood block) with a jack. The jack will allow you to easily lower the engine the 1-2 inches you'll need for the reservoir job.
Only drop as far as is needed so as not to inadvertently over-stretch any electric wires or vacuum lines or hoses. Last edited by jchapura; 10-22-2021 at 06:56 AM.. |
not dropping enough
Hi Thanks for the info taking hoses out still does not drop left side of engine, to clear space to slide out coolent container, the fuel intake is nudging coolent outlet pipe ,engine needs to drop another inch .so anyone has this experience cheers
I read online where the poster said he pushed coolant res as far to front of car as possible then took out the black holder in place piece. That gave enough top clearance. Actually, I believe he took out the right side bolt/screw for the black holder thing, loosened the left bolt and rotated the piece. My issue is I started taking the res out and got it stuck. I stopped and left it for a couple of days. To resume this afternoon.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
This worked well for me. Used 1/4” drive 10” wobble extension with 10mm socket.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
