Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
error code po410
anyone know the cause and fix for this error code?
Thanks!
Old 11-25-2008, 08:20 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Google is your friend - it is the secondary air pump malfunctioning. First I would check the fuse. Then it is on to more diagnostics.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 11-28-2008, 08:44 PM
2fas4u's Avatar
Make sure all connections are tight, and pump is clean and dry for starters..
Old 12-28-2008, 07:18 PM
Porsche Technical
The number one problem for this fault is a bad shut off valve for cars up to and including MY1999. Part number 993 113 245 01. MY2000 introduced a new style valve that does not typically have this problem for the 996.
The 997 uses yet another in which is a Cayenne part number 948 113 203 51.
You may also want to check the electrically operated change over valve part number 996 605 123 01 for all years and the vacuum hoses.
Best Regards,
Scott Slauson
Old 01-11-2009, 04:17 PM
