CEL, I have the codes, Please help
2003 996 Cab, 67,000 miles
I threw my first CEL today. Codes: P0349 Phase sensor 2 camshaft, sub code 113 hall effect sensor P0335 RPM input circuit, sub code 110 Cluster 9114 I did clear the codes and they reappeared when I went down the street. Any ideas for what is involved or parts that may need replacing? Appreciate any input in advance. The car is going to the shop on Monday. TIA
If it has a skirt or tires, it WILL cost you money! |
I'm not here.
Go to 6speedonline.com and ask about this. Lots of knowledge about codes there.
I just recd a voice mail from the mechanic
The cam sensor is one of the culprits causing my CEL. Engine needs to be R&I. Is that correct? Estimated labor time for engine drop? Anyone have a part number or cost on the Cam Sensor?
I'm not here.
First go ask at 6speedonline.com. lots of 996 people there. Ten times as many over there. Or ask Wayne (forum owner) here for help.
Closing this thread with the final results
1 hour diagnostic, 2 hours to replace the right side cam sensor with the motor in, and the part number is 996 606 106 03. thank for everyone's help.
