LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
My 997.2 Turbo S is having an issue where it will never reach operating temperature at highway speeds, but warms up normally at slower in-town driving and then stays warm, even on highway. It seems like a stuck-open thermostat, but a little different. Any ideas?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Carrera Coolant Hose Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article |
Definitely sounds like a stuck open thermostat. I am surprised that you do not have a Check Engine light on.
- Casey |
The first time the problem happened, I took it in to the dealer for inspection and the car did have two codes, P2181 (Thermostat stuck open) and P3081 (Coolant temperature implausible). They reset the codes, and although the problem persists, it hasn't thrown a code again, yet.
Is it more likely the thermostat is stuck, or both the oil and coolant sensors are faulty? I'd bet the former. |
Just to follow up on this... it was indeed a stuck thermostat. Porsche has a revision on the part (.2) and everything is fine again after replacement.
