LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
There are a number of transmission mount inserts on the market which are VERY easy to install. There is no need to remove the transmission, transmission mount or anything. The mount inserts simply fit into the gaps in the rubber mount.
There is one made by Function First which Pelican sells that I have used and reviewed here I have no ties to any of these companies. It made a huge difference in a good way. I'm surprised Pelican did not show this type of product or even mention it in this article. __________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Carrera Transmission Mount Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article |
Yes! I just installed a set of those in our GT3, they work very well because the mounts were not actually bad. I used them to stiffen the setup. I don't think that is a good solution if your mounts are falling apart.
- Casey |
