Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
I got to rant a bit
I changed the transmission fluid on my wife's 997s with tiptronic and what a effing pain.
1. The fill plug and drain plus are tiny. The flll hole is so small the smallest hose attached to the hand pump would not fit. I had to find a small copper tubing to attach to the end of the pump so that I can fill up the transmission
2. What? 45 minutes of warming up the gear box so that I can fill the oil to the appropriate level? Nobody I know would put up with an engine oil duration of 45 minutes. Why would anyone put up with waiting 45 minutes to find out if your gearbox is filled with oil?
I used to have a 1976 Ford Maverick with an automatic transmission. The fill tube is way at the top of the engine, with a long dip stick which has 2 marks, one for cold and one for hot. You can fill it up at any temperature and it takes 3 minutes. Why does this stupid tiptronic NOT have such an easy design? Which engineer thought that having a tiny fill port at the bottom of the car is the right thing to do? You need to be fired.
3. Then after an hour of waiting, refilling to the brim of the fill port, I was only able to add 2 Liters instead of a full gallon that I took out (I measured, I am not stupid). I knew it was low, but according to the book, that is all I could do. This morning, the effing thing shifted funny. So now I have to get it back on the rack tonight to fill it up some more, after waiting 45 mins to warm up.
There has to be a better way. Yes, I know. Don't buy a tipt. Never again. Eff that.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-07-2017, 07:29 AM
2. What? 45 minutes of warming up the gear box so that I can fill the oil to the appropriate level? Nobody I know would put up with an engine oil measurement duration of 45 minutes. Why would anyone put up with waiting 45 minutes to find out if your gearbox is filled with oil?
Old 06-07-2017, 07:31 AM
Old 06-07-2017, 07:32 AM
rufrob's Avatar
I am about to do the same. I also have a Benz W210 supposedly with the same transmission, on which I have changed the fluid many times. Granted the fill tube is much bigger and easier to access. I read the hand pump from a shampoo bottle works well. 30-45 warmup time really isn't that much while you are cleaning up, going the to bathroom and having a sandwich. Make sure the car is leveled and fill it again. Good luck.
Never give up
Old 06-08-2017, 01:21 PM
JFP in PA's Avatar
Well, he could always sell it on and find another Maverick because they are easier to work on......
Accrochez-vous bien de vos rêves..........."
Old 06-09-2017, 09:50 AM
YelCab,
I absolutely agree.
There are several things about that Porsche that are absolutely aggravating, if not unconscionable, considering the amount of engineering (and the cost!) that goes into the car.
To use the excuse of "it's a porsche", and "if you can't afford it, don't get one", or "take it to a dealer" or "these cars are not meant to be worked on by their owners" is unwarranted arrogance and stupid elitism.
Seems like there remains a thread of "a**holed-ness" from the days in the 70s and 80s at Porsche, when they could not design an adequate airconditioning unit, when even the cheapest entry level Japanese car had superior AC units.
I think it all boils down to PEOPLE!
Old 06-10-2017, 02:36 AM
But what a good husband you are--letting her have an easier to drive Tiptronic.
You get all sorts of points for that!
dan
Old 06-27-2017, 09:46 PM
