997 Onboard Monitoring Codes
Using a iCarSoft POR II scanner, within OBD2 diagnostics, "Onboard Monitoring" lists six tests- there are shown as "$01, $02, $03, $05, $06, and $09." Each test shows a "Component ID" such as test $03, component ID $01. these are not generic OBD2 codes, they are assigned by Porsche. Does anyone know where to find a lookup table for these codes?
I have a Carsoft PorII, not sure about six tests and the $ symbols? Mine shows different modules to test and then read DTC and erase DTCs. Is that what you are referring to?
You can also contact icarsoft support and see if they can help you www.icarsoft.com
Dietmar 1987 911 Carrera 2008 RS 60 Spyder Last edited by Dkennel; 11-26-2017 at 12:00 PM.. |
