Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Now in 993 land ...
aigel's Avatar
Need alignment / ride height specs to ask for!
Got an appointment with Kraus Racing in Castro Valley next week. I went through my suspension and need to get it set up for the track. I will have them set the ride height, align and corner balance the car. I do not care about the street much (e.g. tire wear) and want maximum performance for the track. Kraus asks what specs I want. I think they are asking for things like camber and ride height. Please let me know what specs you are running and what you recommend for my setup, especially the folks that have similar cars. Otherwise I will just rely ON their recommendation.
Thanks,
George
Car:
81 SC, slightly gutted (a/c, some interior bits), Saftey Devices Roll bar.
- 21 / 27 hollow torsion bars
- Bilstein HD (front) and Sport (back)
- stock sway bars
- elephant polybronze bushings front
- polygraphite bushigs back
- turbo tierods
- weltmeister bump steer kit (raised steering rack)
- fuchs 15 x7 and 15 x8 with kumho victoracers 225 (Front and back)
- Rennline simple Al strut brace
- everything else stock!
81 SC (sold)
Old 03-29-2005, 08:13 PM
Rough shot at this....you didn't mention ( for example)...tires. Street or DOT rated street/racing, etc.
1.0 to 1.5 degrees negative camber front , max available caster ....."smidge" toe-in.
2.0 degrees negative camber rear..... zero to "smidge" toe in.
If you want a bit more "neutral" handling, at the expense of possibly making it too much tail-happy on long sweepers...match the front/rear cambers. All 1.5 deg...or (more aggressive) all 2.0 deg.
Look at the corner balance thread that I, Craig O'brien and Randy Blaylock were involved in. Important to target equal front ( L-R) corner weights, but only if cross-diagonals are "off" by no more than 5% from ideal 50/50 cross split ( see thread).
OR......
do what the shop says...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-30-2005, 10:05 AM
addictionMS's Avatar
search, there is a thread here where many of us published our specs
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 03-30-2005, 11:02 AM
disband
juanbenae's Avatar
geo, had you considered custom alignment in mt. view?
Old 03-30-2005, 11:43 AM
Now in 993 land ...
aigel's Avatar
k911sc
I have heard of that shop but it is too far away from the east bay. Kraus set up Larry Sharp's car and it looks and performs fabulously. I also asked Joe from Porboys and he sent me straight to Kraus.
Wil:
I actually mentioned that I am running 225 kumhos front and back. They are 15 inch wheels. I forget the aspect ratio. I think the numbers you gave will be a great start! I doubt that Brandon at Kraus does not have a good idea what I'll need, but I wanted to be armed with a few examples of what people do.
Jim:
I searched for suspension and your user name and could not come up with the suspension roll call you mentioned in your reply. Can you help me out with a link to that thread? That would be great.
Thanks all!
George
81 SC (sold)
Old 03-30-2005, 01:16 PM
boy that did take some hunting, and I knew what I was looking for
Race car alignment suggestions.
Jim Hamilton
Old 03-30-2005, 03:23 PM
Blockchain Tech Inventor
jrdavid68's Avatar
Just tell Brandon what you are going to do with the car and whether or not you want an aggressive setup - he'll take care of the rest.
A Mean Green Lifted 1972 C10
Long live the king!
Old 03-30-2005, 04:54 PM
disband
juanbenae's Avatar
for some reason i thought you were south bay. carry on.
Old 03-31-2005, 10:28 PM
Just tell them to look up my specs from when I did it there .. they might have it saved still
2006 Cayman S
93 RS America white(now living in Arizona)
1974 911S/CARRERA (now living in Australia)
Livermore Ca.
Old 04-01-2005, 01:24 PM
Now in 993 land ...
aigel's Avatar
I am just back from the shop. Everything went well. My ride height is a bit high for my taste, but it would have taken reindexing one of the rear bars if I wanted it lower. The dude that does that wasn't here today. Anyway, I got a tad lower than euro ride height now and a nice corner balance. The camber was the max he got out of it.
Best news is that the car weighed in at 2578 pounds with a half tank of gas! I can get this thing under 2500 pounds dry easily if I pull a few more things like sound deadening, power windows and door panels!
Thanks for all your input. Can't wait to try the new setup at Thunderhill next weekend!
George
81 SC (sold)
Old 04-04-2005, 02:07 PM
You're killin' me .......
What specs did you end up with ??? .....
Wil
Wil Ferch
Old 04-06-2005, 01:25 PM
Now in 993 land ...
aigel's Avatar
From the top of my head I can tell you that I got about 1.5 degree neg. camber front and back. 5 or so caster and a rake of 1 degree. Weight distribution was something like 60:40 between front and back. The car sits considerably lower than euro, after measuring it myself via factory specs. I would say about 1.5" lower in the front, I didn't check the rear. The car has great steering response now and I can not wait to see what it does on the track. I had a bump steer problem before and it is cured now, with rack spacers and this ride height.
I can send more detail if you are interested. I think that Brandon got the best out of it without reindexing the rear bars and with what he got out of it with negative camber.
The plan is to run like this for a couple of years and then, when I feel a new alignment would be good, go through the suspension again, with polybronze in the rear and some aftermarket sway bars and maybe hardware that will allow more camber.
George
81 SC (sold)
Old 04-06-2005, 11:20 PM
Sounds good.....we all like to get feedback on what was used in the end, and how it works....
It "sharpens the saw" for the next time we need or give advice......
- Wil
Wil Ferch
Old 04-07-2005, 09:26 AM
Now in 993 land ...
aigel's Avatar
Wil:
I will report back Monday and I can supply exact specs if you need them. I think the exact specs are probably not important, since they are what the car had in it when Brandon set it up. I am sure if the back would come lower by reindexing the torsion bars, he could have put more negative camber in it.
Anyway, I can't wait for Thunderhill!
George
81 SC (sold)
Old 04-07-2005, 01:07 PM
jacko241's Avatar
What did you do with the toe setting?
Joe
996 GT3 RSR
Old 04-09-2005, 07:59 AM
