Automotive Monomaniac
Where do I find harness mounting hardware?
I am looking for hardware to attach my lapbelts to the existing seatbelt anchor points. I understand I can go with longer hardened bolts and mount the OEM belts and specialized brackets (with eyelets?) for my harnesses to snap into.
Where do I find those specialized brackets with eyelets for my belts to clip into?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
If there are not any local race prep or supply shops in your area, try Racer Parts Wholesale.
More Likeable IRL
I.O. Port has them and are west coast.
T$
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Thanks guys. I will check them both out.
- Mike
More Likeable IRL
io has the threaded eye bolts that allow you to maintain the stock belts when desired and clip in the harness when going to track events. you just remount the stock belts with the eyebolt, just make sure you get the longer threaded ones. i had to buy the clips from io port too and replace the other harness mounting equipment. the lap belt i had to cut the stiching and get the clip in units resewn in. the adjustable lap belt allowed me to sew it with 2x the overlap and it was glued before sewing by a shoe repair guy. its passed evey tech of the car thus far.
T$
If you use the clip in type belt attachments, you might want to get some small cotter pins or wire as most organizations want the clips fastened so they can not come off.
Brey Krause makes nice mounting hardware, spendy but nice.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Wow, these are perfect...
http://www.bkauto.com/porsche/r9001.php But, $150 for both seats (4 pieces)? ![]()
Hilbilly Deluxe
On my SC, I used eyebolts in place of the stock seat belt bolts, and snap-hooks on the belts. I am pretty sure I got them from Racer Wholesale, and the whole setup was under $50
![]() ![]() Aren't the seat belts mounted differently on the later cars? I seem to recall someone talking about them mounting to the seat rail on the tunnel side or something like that. Tom |
OG Racing
1978 911SC #737 "D" Class Club Racer |
