Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Which sways should I buy?
Looking to buy adjustable sways. Which ones should I buy and why? thanks Car is a 80 sc that will be used for auto crosses and de's. 23 31 torsion bars , chamber plates and elephant racing bushings all around with 7's and 8's fuchs. At moment have later sways from 87 911.
Old 01-21-2008, 12:01 PM
Driving member
jester911's Avatar
Read this to help with your decision. http://forums.rennlist.com/rennforums/showthread.php?t=404291
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 01-21-2008, 01:13 PM
Southern Class & Sass
Dixie's Avatar
I chose Tarrets. I have no regrets.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-21-2008, 02:34 PM
sway bars
So what I see is that the Smart Racing Bars are the most durable and have the most adjustment because of different sizes. The tarrets would be less money and probably good enough. The other brand breaks! Any one change because of problems. Are 22 or 23 bars big enough?
Old 01-21-2008, 04:03 PM
Crash,
Here is a thread I started in response to the request of several of the racers here. Most of it applies to autocross as well. Lots of reading, but it may help you determine WHY a particular type or feature would be of benefit, and how to make the most of them once you have them.
How STABLE is your Roll Center?
Hope it helps,
Ed
Old 01-21-2008, 05:03 PM
Will I need the bigger bars on the car. It should weigh around 2400 to 2500 pounds. This car had the adjustable sways on it before. Where the bar goes through the front there is hole that looks like it had three bolts around the center where the roll bar would have passed through the unit body. Which bars uses a rounded three bolt pattern where it passes through the body. The smart racing bars look like they have alot more bolts at this junction.
Old 01-21-2008, 06:49 PM
Peter C2's Avatar
+1 on Tarrets, Smart Racing bars hung too low for my car.
'71 911T => POC #388 GP
'89 928S4 5spd/LSD Baltic Blue Metallic Track Shark (SOLD)
'91 C2 Coupe Black/Black (SOLD)
Old 01-21-2008, 10:18 PM
Super Moderator
cstreit's Avatar
+2 on Tarrett. Have them on my racecar.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-22-2008, 09:09 AM
antaircooled's Avatar
I think Weltmeister use 3 bolts on the front and possibly also early factory. I went for Tarrets as they were hollow, look real good and have found them to be excellent as well. I race a '74 Carrera with 21/28 torsions and custom valved Bilsteins, Elephant polybronze all round and Elephant monoballs front and rear. The 22's seem fine for my car and it weighs around 2400 lbs.
Old 01-22-2008, 09:43 PM
+3 on the Taretts
I have run Smart Bars, Taretts, and Weltmeisters. Out of 5 porsches that are raced in my family all 5 have Tarett Sway Bars (all the other brand bars have been sold or sit in the rafters).
Old 01-22-2008, 09:50 PM
Jeff Alton's Avatar
I too have installed a few sets of the Taretts (and had them on my own car). I now have the SRP ones, but see no advantage. There is some marketing hype with the SRP ones. The Tarett ones are much lighter and work great for all but someone who runs multiple tracks that are so different they need to change the bar diameters to get the set up right at each track.....
They are a reasonably priced top shelf product instead of a top shelf priced/top shelf product, if that makes sense...
Cheers
www.turn3autosport.com
Old 01-22-2008, 10:38 PM
Mad scientist
Peter Bull's Avatar
Maybe try a set of knife, or blade, adjustable swaybars?
You get a very large adjustment span without having to worry about overly sharp angles between the the drop link and the lever arm of the swaybar. And the front one can be mounted to a structural part of the car, rather than through the sheet metal in the middle of the wheel well.
It requires some fitting though...
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 01-23-2008, 12:07 AM
914 Geek
In general, the geometry for through-body sway bars is better than that for under-body bars. I do not remember exactly in what way, though.
--DD
Old 01-23-2008, 07:29 AM
Cory M's Avatar
+100 for the Taretts
Interesting set-up Peter. Looks pretty close to the control arm and the stiffness of the steering rack brackets it is mounted to is questionable, but it is an interesting take on it anyway. There are a couple of shops in the US who will make cockpit adjustable bladed 911 swaybars for your 911, they are so expensive they make the Smart bars look cheap (well over $1k each), unless you have a very serious race program you are wasting your money. The Tarett bars are race proven high quality parts, they will provide the stiffness and adjustment you need and they won't break - Pelican sells them too.
Old 01-23-2008, 08:31 AM
Mad scientist
Peter Bull's Avatar
--DD
Hmm, that sounded really convincing, but it is definitely better for this
/Peter
'84 911 Carrera
'91 928 S4
Old 01-23-2008, 08:35 AM
Swat bars
Peter that looks like the same bolt pattern on the ones that were on my car at some time. Does some one have pictures of the tarrett bars as they pass into the unit body. Thanks On the front.
Old 01-23-2008, 08:43 AM
Jeff Alton's Avatar
I wonder why this bar tore the sheet metal?
That is not a design problem per se, but more of an adjustment problem....
Cheers
Old 01-23-2008, 08:59 AM
Mad scientist
Peter Bull's Avatar
It is just a test setup to see which parts need to be moved, or removed. The angle of the photo makes it look a little more cramped than it actually is, but the stock swaybar mount on the wishbone has to go. As you point out, the flat bar that the swaybar bracket is mounted on looks a little weak and will be replaced with a more rigid one. However, until I've decided exactly how to fix the bar I use the stock flat bars.
Including transport and tax, both the Tarett and the SRP setups are more expensive than my setup is. Since I run relatively stiff springs I also need relatively stiff swaybars and I don't want to fix the front one in the sheet metal in the wheel well.
/Peter
'84 911 Carrera
'91 928 S4
Old 01-23-2008, 09:20 AM
Chuck Moreland's Avatar
Cheers
While it is an adjustment issue, I would argue it is also a design issue.
A proper design would place limits on the range of adjustment to prevent anyone from doing this. There should be a stop of some sort.
It is also not clear if this car was equipped with the required backer plates. I don't see them in the picture.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-23-2008, 10:04 AM
abit off center
cgarr's Avatar
We made our own setup with a backing hub and self centering bearings, we will see how it works? No binding!
I do like Peter's design, keeps the weight low
______________________
Craig
G2Performance
Old 01-23-2008, 10:49 AM
