Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
splitter board
Hi,
Anyone know where to get foam sheets or better yet honeycomb foam sheets to make splitters like 4'x6' sheet stock? The sheets need to be big like a splitter and near so. Los Angeles? Any ideas? Everyone I know has small sheets.
Thanks!
Old 02-07-2008, 05:26 PM
Hilbilly Deluxe
emcon5's Avatar
No idea on your question, but foam is about the last thing I would use to make a splitter. I used aluminum, but plywood would probably be better. Tough, relatively light, cheap and easy to work with.
Tom
82 911SC Coupe
GTI Cup #43
Old 02-08-2008, 07:30 AM
gestalt1's Avatar
mcmaster-carr has many sheet materials that will work. they have aluminum, honeycomb core aluminum, carbon fiber, garolite, etc... i think mcmaster has a warehouse near LA.
Old 02-08-2008, 08:27 AM
JW Apostate
trekkor's Avatar
Maybe try a sign shop.
I made mine out of 3/8 inch plywood laminated with fiberglass.
I think 1/4 inch would be fine.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 02-08-2008, 11:57 PM
barney911rs's Avatar
It sounds like he was going to use it as a core for a fiberglass or carbon fiber layout. But I agree that I would rather use aluminum as it is or 1/4 plywood and fiberglass over that. You need something that is going to be more durable then the foam as an underlayment.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 02-09-2008, 01:48 AM
It's a 914 ...
stownsen914's Avatar
The point of using foam is to add thickness to the part (say, .25" or .5" without having to use fiberglass, carbon, or kevlar to make up the entire thickness. You still use as much material as if you just created a plain, flat part, but the increased thickness makes a stiffer part (and still light). Look at the splitter on any prototype -- they're usually about an inch thick. If you didn't use foam to make a part like that, it would weigh a ton.
You can get foam in various sizes and thicknesses for doing composite layups at aircraftspruce.com. Have fun!
Scott
Old 02-09-2008, 03:23 AM
Administrator
Jack Olsen's Avatar
My sources.
For all different kinds of sheet plastic:
Gavrieli Plastic, Metal & Sign
11733 Sherman Way (at Lankershim)
818-982-0000
http://www.gavrieli.com/index.htm
For raw aluminum:
Burbank Metal Supply
3207 N San Fernando Blvd.
818-846-4333
Old 02-09-2008, 01:39 PM
JW Apostate
trekkor's Avatar
make it strong...they take a beating.
KT
'01 Boxster
Old 02-09-2008, 07:05 PM
Walt Fricke's Avatar
Make it cheap. They take a beating.
Walt
Old 02-09-2008, 09:01 PM
Chuck Moreland's Avatar
Make it disposable. They take a beating.
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-09-2008, 09:42 PM
Make a template/mold to make it repeatedly.
John Snodgrass
Old 02-09-2008, 10:01 PM
And give some thought to the mounting. How easy will it be to replace when it gets torn off or otherwise busted?
And how much damage will be done to something else as it is being torn off (assuming it was just an off without smashing into a wall that caused the damage)?
I've never been able to accomplish either of these goals. But good goals they are.
Walt
Old 02-09-2008, 10:31 PM
JW Apostate
trekkor's Avatar
Here's some of my build pics:
Laminated plywood
Mounting brackets
Assembled
Installed
In use!!
KT
'01 Boxster
Old 02-11-2008, 07:40 PM
JW Apostate
trekkor's Avatar
It's attached to the car with 7 Dzus fasteners.
It's never come off.
I have repainted it and done fiberglass repairs many, many times.
I adds a good amount of stability and control at high speed.
KT
'01 Boxster
Old 02-11-2008, 07:44 PM
KT,
I like that, I'm going to "copy" some of those pictures to use a future reference.
John Snodgrass
Old 02-12-2008, 03:09 AM
Splitter material idea
AAR composites is one of many companies that make 4' x 8' fiberglass honeycomb composite panels. The stuff is very strong and light but $. I think a 4' x 8' sheet of .25" thick 2 ply is about $300 + shipping. Good luck!
Old 02-12-2008, 05:19 PM
abit off center
cgarr's Avatar
Here is a honeycomb board, or you could use a foam core sheet and glass it?
http://www.aircraftspruce.com/catalog/cmpages/01-00488.php
______________________
Craig
G2Performance
Old 02-12-2008, 06:30 PM
