Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Finding the apex
My son, 11, has been taking karting lessons at Jim Hall in Oxnard. I've been doing it too. It is an absolute blast of course. They of course has shown us where the braking zones, trail braking zones, and apexes are on their whole track. But, they actually haven't instructed how to analyze any given corner for other tracks. Of course like any 44 year old guy with an overinflated ego who has been driving sports cars for 30 years, I have a belief that I somewhat understand finding a good line and apex of various corners. But, I realize I really don't know for sure.
This weekend, my son is having his birthday party at the MB2 indoor go kart track in Sylmar. I'd kind of like to be able to discuss with him the best lines for that track. I've been trying to find something on line that will help with tips to supplement what I know I don't know. I've searched without much luck.
Anyone know of anything on line?
Unfortunately, I do know that the track layout that MB2 has on their web site is not their current track set up.
Thanks.
Old 02-12-2008, 08:30 AM
304065's Avatar
Driving in competition by Alan Johnson. Best thin single volume about analyzing corners and working up new tracks there is. Not online, but can be bought online cheap.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-12-2008, 09:02 AM
jluetjen's Avatar
I'm a big fan of "The Technique of Auto Racing" by Piero Taruffi. For the video generation, there's also "Going Faster" from the Skip Barber racing School. Both do an excellent job of describing the apex.
Skip's video sums it up as...
1) Start with a late apex, which will result in you having left over road at track-out. It's safer.
2) Incrementally make the apex earlier until you are tracking out right on the outside edge of the pavement.
In all cases you should be turning smoothly, without pinching the corner at the apex.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-12-2008, 09:09 AM
Michael Delaney wanna-be
Netspeed's Avatar
Thanks.
There's an indoor kart track in Sylmar? Awesome! I always thought the only one around was Dromo1 way out in Anaheim. How does it compare to Dormo1 and do you have a website or link to them?
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 02-12-2008, 09:51 AM
porsher
aston@ultrasw.c's Avatar
As a newbie to closed circuit driving something dawned on me the other day.
It's OK to talk about apex, turn in point, braking point and so on but when one is out on the circuit, we must not look directly at any of these points!!
My instructor often tells me to; look across the corner, look down the straight, keep my head up etc...
I find I drive much smoother (and hence faster) if I keep my eyes focused down the track and only allow specific reference points to float in and out of my peripheral vision.
Anyone else experience this, or has another way of describing it?
Old 02-12-2008, 10:41 AM
http://mb2raceway.reachlocal.net/
It's off the 405 right after leaving the Valley and becoming the 5.
Old 02-12-2008, 11:21 AM
gulf911's Avatar
The apex is of course the center of the corner, hence, the terms late apex, early apex etc., how you approach a particular corner can depend on the car, the next corner etc. You will generally read you want to be at or near full throttle at the apex of the corner. That being said, being on the gas as early as possible through the corner to exit will usually result in faster times. The hardest part sometimes is usually trying not to turn in too early. use late apex's to start with and then try to see where you can get on the gas early and shoot out of the corner. Anyway, just some thoughts. YMMV.
Old 02-12-2008, 12:28 PM
914 Geek
Another good book, "Secrets of Solo Racing" by Hank Watts.
A good mantra for most track experiences is, "Look ahead look ahead look ahead look ahead". You are supposed to look for your turn-in, apex, track-out points--but you should not be looking directly at them, most especially while you are driving by them! If "letting them drift in and out of your peripheral vision" is how you can keep looking further ahead, that's perfectly valid.
I personally try to focus and commit the car to a path. I then try to shift my attention to the next thing that I can affect, while keeping in mind the adjustments that are needed to make the car actually do what I have committed it to do in my mind. At least, that's what I'm trying to do; it doesn't work nearly as well in practice.
--DD
Old 02-12-2008, 10:28 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
It's simple; the driver who turns his front wheels the least wins.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 02-15-2008, 04:32 AM
Netspeed's Avatar
Very true...unless you're rallying
88 Carrera Cab
Old 02-15-2008, 06:26 AM
Thanks everyone.
Old 02-15-2008, 07:06 AM
Smart quod bastardus
fredmeister's Avatar
A good way of finding the apex thru a turn is to see where the cement has been added to the track asphalt surface. Usually the track is torn up by cars on the fastest line thru the turn, so they need to repair the damaged areas by ading cement to and ordinarily asphalt surface. Next track day your on keep that in mind and see if running the cement surface tracks thru the fastest line and likely the apex for the turn.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-15-2008, 01:14 PM
