LSDs
Sort of a follow up to my previous transmission thread:
I've found somebody to rebuild my G50 along with a ZF LSD... First, for a dedicated track car (roll cage), what do you all recommend as the % locking factor?? I've read 80% but the tranny guy I spoke to said 40% is enough and easier to drive. Also, I almost never autocross. Should I stick with 80%?? Second, needless to say, the steel synchros REALLY add to the price... My only problem is grinding when upshifting into 3rd gear... Is it reasonable to replace ONLY the 3rd gear synchro with steel, and the others with the softer OEM stuff??? I'm not trying to be cheap but this is an unexpected rebuild (and I'm not somebody that has more money than I know what to do with)... Thanks for the suggestions-
Jack E class '87 911 |
http://rennsportsystems.com/2d.html
http://www.rennsportsystems.com/1-d.html Good article from a respected Porsche expert, Steve Weiner.
Eric 1978 spec 911 1998 C2S |
Super Moderator
80% lockup would definitely be over the top for a street LSD. You'd be leaving black streaks in your driveway and street corner as the wheels skipped during tight slow turns. 40% is certainly acceptable for most situations.
The Guard LSD that I ordered in February FINALLY came in last week. Had it put in and yesterday but won't be back in the city to test it out until next week. I ended up going with a 40/60 split at numerous peoples recommendation. I hear 50/80 is really the hot setup for the track but as Chris mentioned would be pretty annoying on the street. I'll be back at the track in three weeks and can't wait to see what kind of difference the LSD will make over my open diff.
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
Schleprock
Keep us posted Rob. Interested to see what kind of time you shave from your typicals.
As far as the original post, i'd forego the steel synchro arrangement. Mine stock brass stuff just started crunching at about 75K miles. I'm sure you'll get PLENTY of life out of new brass parts as long as you: 1. treat the car right and don't abuse with lightning shifting, 2. ensure that the engaging pieces are all replaced so as to have a new interface between all parts that match gear speeds. This is not cheap either. As long as you're going thru the trouble to rebuild, you'd be wise to get the plasma discs that Guard offers to extend the life of the ZF diff.
Kevin L '86 Carrera "Larry" |
for street 40%, especially if the re-builder is using Paul's plasma coated disks. The % doesn't tell the whole story anyhow. High preloads can send the breakaway torque way up even though the theoretical # is 40%
The ultimate is an asymmetric unit such as the Guard 40/60 or 50/80. W/ them you get the best of both worlds, you want the high # for deceleration, but want the low for cornering
But fellas, my original question was for a 99.9% track driven club racer!!!... NOT a street car. The only street driving will be to and from my mechanic's shop. I appreciate the replies but all the advice has been for street cars...
The tranny is done and the ZF LSD locking factor was set to 80% per my request... I hope it's good. It'll get re-installed next week... but not back to the track until the end of September... BTW Kevin, I agree regarding the brass vs steel synchros. But as a compromise between durability and price, I opted to use steel for the 3rd gear synchro only...
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Now that's what I wanted to hear. Thanks!!
I am also running a 80/80 factory ZF. I drive to the track and the mechanic with no problems. On the track it is definately worth more time, probably more under braking (much more stability) than drive out of corners, but time is time.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
I will likely keep the 40/60 setup thru next season and see how I like it. May then pull it out and flip it to the 50/80 setup and see what kind of difference I see.
Can't wait to test this thing out!
