another roll cage question: Bar under dash needed by PCA rules?
I have a 88- 911, that has a full roll cage and was raced for 4 years, but last race was in 2004. I plan on racing it again in 2009. I was at a recent NASA event and a couple of the 911 guys there mentioned that I needed the bar that goes below the steering wheel, just under/at the lower dash edge level. I can't find any rules about this in the PCA rulebook. Does anyone out there know for sure?
Thanks. Hunter
++++++++++++ 1988- 911 Targa-Track car 2000-Ferrari 360 Modena F1 2004- BMW M3-Dinan Stage 3 |
It is not required for PCA or NASA racing. However I would recommend one.
Jack E class '87 911 |
Thanks Jack. Appreciate the confirmation.
Will see if my local guy can weld one in anyway as it does seem like a good idea. Hunter
Navin Johnson
If the rules don't explicitly say you need a bar such as that, don't add one there have been multiple threads here and in rennlist regarding roll cage design... consensus is that bar is best for breaking knees... not much else..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Super Moderator
Tim, got a link to those threads?
If you remove the lower dash "lip," the bar can be located in it's place... therefore posing no more risk than the stock dash itself. And believe me, I used to be a paramedic and I saw plenty of femur fractures in UNrestrained drivers in front-end collisions. So I know that the theoretical risk exists... just not with a properly constructed cage with a properly restrained driver. Poll any of the reputable cage builders around and you'll see that a good cage includes this "dash" or "knee" bar every time.
Navin Johnson
whatever
Some of the same questions are bandied about in this thread that bar doesn't see alot of stress, it really doesn't do much in the grand scheme of things. btw one of the cages I have built that knee bar is there because the customer wanted a knee bar
Navin Johnson
It's a 914 ...
All makes sense as long as the car isn't hitting anything. But what happens in a massive side impact when there's no knee bar (or through-the-dash bar) to stop the cockpit from collapsing laterally? Scott |
Ah clever, Tim. Dig up a quote of my own that seems to contradict what I'm saying. It's true that I once questioned the safety of a dash bar. People I trust and respect reassured me.
My cage builder was able to install the bar so that it's about 6 inches from my knees, which I'm very comfortable with. Again, it's tucked away in the exact location of the previous lower dash. If it was in front of the dash and with a pad, it would be close. Not that it makes it right, but I'd say that, for some reason, 9 out of 10 custom cages have this bar (and even several of the bolt-in ones, too)...
This car had a Safety Devices cage installed. This cage did not have a knee bar.
Look at the driver's side a-pillar at how far the cage has been pushed in. I think a knee bar would have strengthened the cage, and limited the side intrusion. This pic also shows why a good door bar set-up is important.
Doug Crossman #92 1992 964 PCA G class #902 1979 911 PCA 911 Cup 96 993 Targa |
Navin Johnson
Actually I found that quote when I was searching for some of the FEA stuff jluetjen did. I also did some models which were on a laptop that was stolen, and haven't taken the time to rebuild them.
Its show that if you removed the knee bar the stresses in the cage remained the same, or in other words,the cage performed the same with or without the knee bar If you get that bar tucked way out of the way fine, you carry around a few extra pounds. I think one overlooked spot in cage construction is the floor. I've seen a car that was balled up and the pedal cluster was pushed almost halfway to the seat ![]() I saw pictures somewhere of a car with some floor bars, Gunnars sight maybe?
Navin Johnson
I still cant find , but there was an epic roll cage thread a few years ago. Dont remember if it were here or rennlist
I was at the track when the #38 car Doug posted above was hit and after seeing it added a knee bar to mine before I raced again. Without a cross bar at the A pillar to transfer the impact the cage simply moved inward on the driver.
Bill M 88 Carrera 86 944 SP1 06 Cayman SPC Last edited by zzwhm; 12-01-2008 at 01:27 AM.. |
I'm not sure what PCA would think of it (because it reinforces and stiffens the chassis) but you would probably gain a lot of side impact structural integrity if you could tie the center tunnel and the side sills together. The knee bar is doing this to some extent but not as effectively because it's up and away from the sill. Perhaps you could add some rectangular section tubing laterally at the floor level between the sill and the tunnel. You would have to reinforce the ends to protect against punch through but I bet it would keep the sill from bending in towards the center of the car in a low height side impact.
I also like the idea of adding high density foam (like roll bar padding but in sheet form ) to the left side of footwell area.
'83 SC |
'83 SC |
It's a 914 ...
The testing you quote above -- was that a destructive test? Quote:
Scott |
Wondering aloud, new cars are made with a "crush zone" to absorb energy during an impact. Is it possible to design/make a cage that is too stiff?
PCA-Chicago Region-DE Tech Coordinator-Retired PCA-Chicago Region GingerMan DE Co-Chair-Retired 1987 Cab-under construction-Sold pending pickup 1986 911- Race/DE car-Sold |
disband
looking to cage up too in the very near future and was wondering if some photos might be shared here? not to highjack, but you know.... on theme..
thanks
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
It's a 914 ...
With that said, cars that have tubing outside the cockpit for stiffening purposes can be designed with smaller diameter or thinner tube in the front and rear portions of the tube frame. This allows for some crush in the extremities while ideally transferring less stress to the roll cage (cockpit portion of the tube frame). Scott |
